fuel pump
check the wiring that goes to the fuel pump that is located at the center of your rear seat with a test light. have somebody turn the key on while somebody else checks if the light turns on at the fuel pump wire. if it turns on and the car doesn't start maybe you need a new fuel pump. if the test light don't turn on, its probably the main relay.
iHave2Cams
May 5, 2003 04:29 AM
