civic problem Help
Old May 28, 2007 | 04:18 PM
90 civic hb's Avatar
Default civic problem Help
I have a 1990 civic ef i bought a year ago and i have a problem, when i turn on the car, black smoke comes out of the exhaust? what could it be?maybe a sensor? I don't know please help out? I will appriciate it.
Old May 28, 2007 | 04:35 PM
Hondamonster's Avatar
burning oil? old gas? more info?
Old May 28, 2007 | 04:47 PM
Default Re: (Hondamonster)
the engine is totally rebuild. it could't be burning oil.
they told me it could be a sensor? what do you think? reply back thanks
Old May 28, 2007 | 05:29 PM
Default Re: (90 civic hb)
has the car been sitting for a long time? any other problems with running?
Old May 28, 2007 | 05:44 PM
garageEF's Avatar
its probably fryed rings. do a compression test.
Old May 28, 2007 | 05:47 PM
it was sitting for a while, for like about maybe 6 months. the rpms are also low and also when you shift to second gear it kind of chokes.
Old May 28, 2007 | 05:50 PM
after 6 months of sitting we rebuild the engine completly. i don't think it could be the rings. do you think it could the timing belt that is not put on time. what do you think?
Old May 28, 2007 | 06:09 PM
check your fuel system. if you are using the old gas, drain it and flush the fuel lines. also get a new fuel filter. i may be wrong, but it doesnt sound like timing, but check it anyway... its not that hard. look for the up arrows on the underdrive pulley and timing gear to match up
OvertheCliff79
Honda Civic (2001 - 2005)
Jul 16, 2011 03:49 PM
lilshady6796
23
May 27, 2009 07:48 PM
capm.stabahoe
Dec 27, 2008 06:17 PM
wez
Apr 24, 2006 05:22 PM
NSX4evr2006
Apr 23, 2006 12:56 PM
