annoying beep
Old May 28, 2007 | 02:48 PM
v-tecnition's Avatar
Default annoying beep
does anyone know how to turn of the annoying beep when your keys are in the ignition and the door is open????
Old May 28, 2007 | 04:54 PM
fdavie's Avatar
Default Re: annoying beep (v-tecnition)
Go under the dash and disconnect the thing that's beeping. Keep it there, because you'll want to hook it back up the next time you lock your keys in the car.
Old May 29, 2007 | 08:20 AM
Default Re: annoying beep (fdavie)
The thing is i cant find the damn bepper thing what the hell does it look like
Old Jun 1, 2007 | 08:58 AM
bump
Old Jun 1, 2007 | 10:06 AM
ifIexplode's Avatar
Leave it in there. it goes..
Honda da da... honda da da ...honda da da... honda da da
Old Jun 1, 2007 | 10:17 AM
pdiggitydogg's Avatar
It makes it so you dont become a moron and lock the keys in the car......just leave it in there, it doesnt do any harm
Old Jun 2, 2007 | 06:53 PM
dadsvtechonda's Avatar
you cant take the beep out its in the back ot the fuse box its called the ICU the icu is important i wouldent mess with it
Old Jun 2, 2007 | 06:58 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: annoying beep (dadsvtechonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">It makes it so you dont become a moron and lock the keys in the car......just leave it in there, it doesnt do any harm</TD></TR></TABLE>
x Nine-thousand-six-hundred-sixty-two.
Old Jun 2, 2007 | 07:19 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-tecnition &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know how to turn of the annoying beep when your keys are in the ignition and the door is open????</TD></TR></TABLE>
Use bubble gum or duct tape to hold the contact switch on the door jamb closed . . .
Or take the keys out of the ignition. Or close the damned door.
Old Jun 2, 2007 | 07:21 PM
Exploziveaf1's Avatar
had same problem beeps while driveing, un hook battery and hook back up
Old Jun 2, 2007 | 09:42 PM
anavrin351's Avatar
Default Re: annoying beep (Exploziveaf1)
i listen to tunes while i clean the inside of the car, and i cant lock my keys in the car. i want the beeper gone. i've woundered this for a while but i always forget to post.
Old Jun 2, 2007 | 09:49 PM
Winlight's Avatar
Default Re: annoying beep (anavrin351)
im pretty sure you can just unhook the wire that goes to the botton on the door.
Old Jun 2, 2007 | 09:56 PM
anavrin351's Avatar
Default Re: annoying beep (Winlight)
i'm affraid if i do that the beeper will be constant. with my luck i'll never be able to reconect the thing
Old Jun 2, 2007 | 10:03 PM
SIC-CIVIC's Avatar
if you do that, your dome light won't work either.
Old Jun 2, 2007 | 10:08 PM
Eran's Avatar
HT White Ops
Here's a smart idea ... turn the key to (II) ... then it won't beep.
Old Jun 2, 2007 | 10:09 PM
truevietluv636's Avatar
Default Re: annoying beep (SIC-CIVIC)
remove the drivers side door switch. noise is gone but no dome light switch when drivers side door open. better yet, do what i did, hook up a switch in series with the drivers door switch.... when your working on your car turn off the switch... on normal days turn on the switch.
Old Jun 2, 2007 | 10:16 PM
anavrin351's Avatar
Default Re: annoying beep (truevietluv636)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Here's a smart idea ... turn the key to (II) ... then it won't beep.
The only time it doesnt beep is when the car is running. To have tunes on it has to be set to II. Key in the ignition while its not running the thing beeps. I dont care about the dome light not coming on when the door opens. Thats why theres a ONdoor/off switch. If i need it i can turn it on.
Old Jun 2, 2007 | 10:32 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anavrin351 &raquo;</TD></TR><TR><TD CLASS="quote">
The only time it doesnt beep is when the car is running. To have tunes on it has to be set to II. Key in the ignition while its not running the thing beeps. I dont care about the dome light not coming on when the door opens. Thats why theres a ONdoor/off switch. If i need it i can turn it on. </TD></TR></TABLE>
To have "tunes" on ... it has to be set to (I) ... accessory. If you turn it to (II), which is Ignition, the car will be on for all intensive purposes. The only thing that won't be running is the engine itself. Here's a video I just shot to show you that the beeping stops.
http://www.youtube.com/watch?v=8WdKKdz1GL4
The proof is in the pudding.
Old Jun 2, 2007 | 10:42 PM
GarageAlchemist
Guest
Posts: n/a
Default Re: annoying beep (Eran)
lmao, pwnage.
Old Jun 2, 2007 | 10:54 PM
Jhonny Ricer's Avatar
Default Re: annoying beep (GarageAlchemist)
Lol I love how people go out of their way here on H-T to be ******** to stupid remarks. If your beeper is on when your at the II selection in your ignition and it still beeps sounds like you broke something.
Old Jun 2, 2007 | 10:59 PM
GarageAlchemist
Guest
Posts: n/a
Default Re: annoying beep (Jhonny Ricer)
it goes off..
Old Jun 2, 2007 | 11:04 PM
He said his doesnt in the number II selection or at least thats what I read oh well.
anavrin351's Avatar
i never knew it would eventualy shut off after about 5 seconds. it even changes its tone after going from I to II. Some dash lights and the heater came on, but now i know.......bitchin
Old Jun 3, 2007 | 03:49 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">for all intensive purposes</TD></TR></TABLE>
The phrase is "for all intents and purposes," buddy.
Old Jun 3, 2007 | 04:40 AM
bart2546's Avatar
Default Re: annoying beep (Targa250R)
One of the most interesting threads of June 3rd 2007...haha..
Yea having it on II should/will make the beeps stop. I never liked having it sit there on that selection due to the fuel pump priming for those couple of seconds then the engine not using it...could be me just being paranoid but I just don't like it. More or less its up to you, the owner, on how much trouble you want to go through to make it stop. If you have time a patients you could probably bypass it with a switch so the dome light works or something but I figure it's just a stupid little beep and I turn it to I for acc, turn on the tunes, roll down the windows and shut the door. Good luck to ya though.
