Car won't start
Old May 28, 2007 | 09:50 AM
Syed Shah's Avatar
Default Car won't start
Hi everyone,
I have a 1999 1.6VTI (B16A2) Civic.
After sliding down a verge (no damage, but steep verge); she won't start. The engine turns but won't catch.
I first suspected ignition, but all checked and is ok.
So fuel is the only other logical choice. Is there some kind of safety feature that cuts the fuel after a 'crash'? Any other ideas?
Thanks
Old May 28, 2007 | 09:58 AM
ke98248's Avatar
Default Re: Car won't start (Syed Shah)
Did the air bags deploy? I'm assuming no. Do you mean that the engine start to go but dies before it actually turns over and fires up, or that it primes and just tries to start like a person with a dead battery.. Check your grounds, wiring to starter, battery, alternator..
Old May 28, 2007 | 10:29 AM
Syed Shah's Avatar
Default Re: Car won't start (ke98248)
No airbags deployed.
It just turns over. Like if you have a new battery, but no spark plugs.
Checked the electrics (when I check the ignition components). Hence why I think some kind of fuel-cut issue.
Old May 28, 2007 | 11:10 AM
ProjectTib's Avatar
did you check the battery and make sure none of the wires fell off while you were sliding? try jumping it and see if it starts.
Old May 28, 2007 | 11:11 AM
ProjectTib's Avatar
maybe you caught a fuel line and broke it open or something and its not gettin enough fuel to the motor
Old May 28, 2007 | 11:12 AM
b16crx88's Avatar
timing is off
Old May 28, 2007 | 12:21 PM
Syed Shah's Avatar
Timing off? How would that have happened?
Tried a jump start, no luck, so definately not battery related.
There are no leaks, so I would assume that is ok. ?
Old May 28, 2007 | 02:24 PM
Syed Shah's Avatar
*Bump*
Old May 29, 2007 | 10:03 AM
b16crx88's Avatar
stranger things have happen to me.. including timing jumping. after starting my daily driver and letting it idol, turn it off and turn it the key and it would just crank...didnt even move my car!!
StreetRiot_DRE
Feb 21, 2010 03:35 PM
jonnybadboi9
Jan 31, 2007 11:16 PM
zacatkings
27
Mar 22, 2006 05:26 AM
rainmanef
Jan 11, 2005 08:07 PM
posterchild
Jun 26, 2004 02:09 PM
