help!! wiring problem smoke coming out!!
well today i was driving my car like normal and when i got home my car started to smoke.. i open the hood to fine out that the box fuse has smoke coming out and my radio shut off.. well when i looked at it the 7.5 backup fuse is burning and melting so now i need a totally new fuse box.. i took out my radio to also find out that some of the wires are crisp and burnt.. what can be causing this problem?? thanks lmk i really need help~~~!!! the car starts fine and everything works except radio since i took it out.. should i just part out the car? also how much are new dash wires?
holy f*ck i just took out my cluster to fine out i burnt a wire and my harness is pretty much fucked!!.. how much would a harness cost? im talking about the wires that are for the radio and cluster also the wires connected to the engine bay fuse box..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambosoup »</TD></TR><TR><TD CLASS="quote">holy f*ck i just took out my cluster to fine out i burnt a wire and my harness is pretty much fucked!!.. how much would a harness cost? im talking about the wires that are for the radio and cluster also the wires connected to the engine bay fuse box..</TD></TR></TABLE>
Mucho dinero
32117-SR3-A31 WIRE HARNESS, INSTRUMENT $217.73
32100-SR8-A20 WIRE HARNESS, CABIN $723.86
Mucho dinero
could it be because i didnt screw the ground wire from the rad support to the valve cover? well anyways im trying to salvage the harness but most likely will get a new one.. also is the cabin harness the one for the engine bay fuse box? thanks lmk
hmm thanks for the help guys. you think it can be the radio? because i recetly had a friend install my radio. or can it be bacue im not putting the rubber seals on my headlights you know the one you put after the light bulbs?
