Power Windows Question!
Old May 28, 2007 | 09:04 AM
jpnucrx's Avatar
Default Power Windows Question!
I have a 99 Hatch and have all the 00 Si Power Windows Put in the door. Keep in mind Im wiring it without the floor harness. I go the blue/black wire to power, and the black wire grounded.(For Drivers Side Window). I have 12 volts at the switch, but the window wont go up and down?...How Do I check for voltage at the motor...im not sure which wire?...please help...its 80 degrees and i cant put the window down
Old May 28, 2007 | 02:43 PM
jpnucrx's Avatar
Default Re: Power Windows Question! (jpnucrx)
up...the pass. side works great
the drivers side window is stuck down...when you hit the button to go down you hear the motor...but when you press it to go up, it doesnt make a sound...could it be the switch?....HELPPPPPPP
Lightsped
Jul 27, 2013 09:35 PM
spnej1
16
Mar 3, 2008 06:32 AM
Ej1_coupe
May 29, 2006 06:39 PM
