car wont start???
Old May 27, 2007 | 11:56 PM
99Civic-EX's Avatar
Default car wont start???
i just replaced the thermostat in my d16y8, everything was fine except it overheated which is why i replaced the thermo, which was shot. i put everything back together, went to fill my radiator with new coolant and it wouldnt start. it cranks over but wont fire up. any idea why it did this? i checked over everything and everything seems to be connected plus i even tried a different battery thinkin that might have been it. any help would be appretiated.
Old May 27, 2007 | 11:57 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: car wont start??? (99Civic-EX)
did you check for fuel and spark?
Old May 28, 2007 | 12:01 AM
99Civic-EX's Avatar
yeh i checked for spark and it was there
Old May 28, 2007 | 12:02 AM
Throwdown's Avatar
Default Re: (99Civic-EX)
what about fuel?? is the pump coming on? if not ..check your main relay..you checked all your grounds did you unplug anything when installing the thermo?
Old May 28, 2007 | 12:04 AM
99Civic-EX's Avatar
the only thing i unplugged was the censor that plugs into the thermostat housing, which i put back in, and yeh the fue pump kicks on. nut i didnt check any of the main relay's
Old May 28, 2007 | 12:06 AM
Throwdown's Avatar
well something not making sense if everything is plugged up right and ground you have fuel you have spark then all thats left is timing did you check that maybe it jumped
Old May 28, 2007 | 12:08 AM
99Civic-EX's Avatar
no i didnt check timing, but everything else looks good........on a second look at the spark, i tried all the plugs and one wasnt sparking, but the rest were think i found my problem
Old May 28, 2007 | 12:30 AM
raymundojr's Avatar
Try to look at those AC connections,and the spark plugs maybe worn out and need to be replaced unless its problem is connected with the honda clutch.
Old May 28, 2007 | 12:41 AM
DCSportEJ1Civic's Avatar
to check if the injectors are firing is easy. they always have power when the key is on. so get a test light and check for power on the injector. but the way an injector fires is a ground pulse. it grounds to fire and ungrounds when its not open. this is simple to check with a test light. your lookin for a ground so take the gound of the test light, the little alligator clip and put it on the positve of the battery so it has power. then all it needs is the ground. so probe the ground wire of the injector and have someone crank the engine. the light in the test light should flash on and off quickly while cranking. this means the inkector is working correctly. if it doesnt light up at all there could be a relay or fuse blown, or something unplugged. anyway i hope that helps.
Old May 28, 2007 | 09:58 AM
99Civic-EX's Avatar
so i found some loose ground wires, i tried turning the key to see if maybe that was what it was and the fuel pump wouldnt turn on. i connect the grounds back on and the fuel pump started up and so did the car, so i took it for a little test drive down the street and the speedometer didnt work, then the car stalled out and the fuel pump wouldnt kick back on again. idk what to do this sh*t sucks.
Old May 28, 2007 | 11:34 AM
99Civic-EX's Avatar
bump......anyone???
Old May 28, 2007 | 12:10 PM
eskimo10's Avatar
check your fuses, see if maybe they blew or something, i know the speedo and the fuel pump both have one under the dash.
Old May 28, 2007 | 01:16 PM
99Civic-EX's Avatar
pretty sure it was just bad ground wires, im gunnna re-do them later and see if it helps any.
Old May 28, 2007 | 01:31 PM
eskimo10's Avatar
Yea definetly make sure the grounds are good, clean them up real well, you may even need to shave some of the paint or if there's any rust or anything.
Old May 28, 2007 | 05:02 PM
cyb593's Avatar
i am having the same problem with my 93 del sol.
Old May 28, 2007 | 06:13 PM
pissedEK's Avatar
I've had the same problem before, there is a ground that attaches to the thermostat housing that many people overlook, believe it or not your fuel pump will not kick on unless this is clean its right underneath your upper hose on the housing.
Old May 28, 2007 | 07:20 PM
cyb593's Avatar
will check it but it was doing it before we took the thermostat out. could it be the sensor that plugs into the thermostat. is that replaceable?
Old May 28, 2007 | 07:25 PM
1d10t's Avatar
Default Re: (cyb593)
no its not that sensor. there are a group of grounds( about 3 wires) @ the thermo housing. they are ecu grounds. has to be it
Old May 29, 2007 | 02:44 AM
cyb593's Avatar
Default Re: (1d10t)
i am not saying you are wrong i am just saying the grounds werent loose before i took the thermostat off. well atleast they didnt seem loose because we had to break that bolt loose. it was on there. but my point is that it was acting the same way before we took the thermostat housing, the thermostat and the grounds off. i will check it it is a easy fix!! thanks for your help just seems a little to easy. I definetly will check and let you know.
Old May 29, 2007 | 07:35 PM
cyb593's Avatar
regrounded everything and still the same issue.
feava510
Feb 15, 2009 10:59 AM
drew_kousk
21
Jul 20, 2008 08:25 AM
lazykiwi
May 13, 2004 11:55 PM
pikappaphi
15
Jan 22, 2004 06:57 AM
johnjohn410
Dec 17, 2002 10:21 PM
