possible to run a P2E ecu on a gsr?
Old May 27, 2007 | 08:56 PM
makavali27's Avatar
Default possible to run a P2E ecu on a gsr?
Hello, my 97 dx hatch has a obd1 gsr swap and I am using obd2 to 1 conversion harness running a p28 chipped. I am wondering if its possible to use the stock ecu, The P2E obd2 ecu on the engine just to pass inspection? I am having problems with inspection and they said if i can run the stock ecu that came with the car, it will pass. any thoughts?
Old May 27, 2007 | 09:23 PM
Luserkid's Avatar
Default Re: possible to run a P2E ecu on a gsr? (makavali27)
Itll throw a code and run like ***. Other then that you could use the ecu
Old May 28, 2007 | 03:24 PM
makavali27's Avatar
Default Re: possible to run a P2E ecu on a gsr? (Luserkid)
wondering what code will it throw... I have no other choice bc I can't get my car inspected..
makavali27's Avatar
bump
JohnData
13
Apr 26, 2010 06:11 PM
DOHC Kid
May 27, 2008 05:41 PM
v-tec maz
Apr 19, 2006 09:35 AM
LpBoy2004
Feb 13, 2004 11:16 PM
totaled
32
Aug 17, 2003 09:30 AM
