Yellow/white electrical wire for car stereo dead -- not red one or anything else on fuse
Old May 27, 2007 | 05:30 PM
MrBryan's Avatar
Default Yellow/white electrical wire for car stereo dead -- not red one or anything else on fuse
Hi there,
I'm a bit puzzled at this:
92 Honda Accord
The yellow & white power wire for the car stereo stopped working. It's the main power source -- the one that stays on after the car turns off so that the memory stays and the unit has a chance to power down properly.
Right now I have the red wire spliced to both power inputs on my deck, but i lose everything every time i turn the car off.
Any ideas what would cause this one wire to fail and not the others?
Or, is there another source I could run a wire to that remains on after the ignition is shut off?
I pulled some strange plastic box that had a coiled wire inside it that was in between the stereo and the power source on said yellow/white wire -- I think it was put there by a tape deck installer from years ago -- or maybe its crucial and it failed and its why its not working.
Any tips appreciated.
Old May 28, 2007 | 04:27 AM
Jstall7543's Avatar
did you check the radio fuse in the fuse box? if not blown then rewire it , one wire needs constant power and the other need to be a switched power sourse to work properly! the red on the deck will need the constant power.
Tyler Harteau
Oct 18, 2018 09:19 AM
KrispyKreme
Audio / Security / Video
12
Mar 17, 2005 01:13 PM
itsJDMyo
Nov 24, 2003 01:02 PM
Sirus
Oct 5, 2002 09:04 PM
