91 Civic LX won't start
Old May 27, 2007 | 01:27 PM
cessnapilot's Avatar
Default 91 Civic LX won't start
I was driving, the car cough, a little black smoke and she quit running. I checked spark. Fire at plugs. I checked for a code. None. When I turn the key to on I get one quick flash at the ECU then nothing. No code on the ecu means bad ecu. Before I replace the ECU I was wondering if there was anything that could prevent the ecu from working. When I first turn the key to on I get the wirring of the fuel pump and the click (main relay). Any thoughts.
Old May 27, 2007 | 01:50 PM
garageEF's Avatar
Default Re: 91 Civic LX won't start (cessnapilot)
sounds like a mechanical problem(blown HG, etc.) your ecu is fine... that first flash means it has power and is working correctly. do a comp. test.
Old May 27, 2007 | 01:53 PM
cr-x-91's Avatar
check plugs for coolant...
Old May 27, 2007 | 02:17 PM
garageEF's Avatar
Default Re: (cr-x-91)
pull of the valve cover and look at its underside....if it has milky brown **** all on it you have a blown HG...
Jared95
Honda Civic (2001 - 2005)
Feb 9, 2018 06:55 PM
91integragsr
Mar 26, 2012 08:16 PM
cessnapilot
May 28, 2007 05:17 AM
heredago
14
Jan 14, 2007 09:41 AM
B17EF
Nov 27, 2002 07:33 PM
