help>>>stock sleeves question
Old May 27, 2007 | 12:45 PM
lsvtechatch92's Avatar
Default help>>>stock sleeves question
i have a piston and rod lsvtec with valve springs and retainers on stock sleeves...
it made 408and 306 on 4th gear pull on pump gas...and after dyno it started to misfire...it has a hairline crack in number 3 cylinder... is 400 hp to much for stock sleeves and pump gas...i have seen it on many other cars.. or do you think it was just a freak accident...what numbers do you guys see with pump gas and stock sleeves...
i found gsr block forcheap so i am putting my ls crank and what not in the gsr block... hopefully it will not crack another sleeve... if it does i will be forced to sleeve the next one
dantamparacer
Jul 27, 2009 11:52 PM
x still jaded x
Jun 8, 2008 09:33 AM
wespirl
Aug 24, 2007 03:32 PM
lsvtechatch92
Jun 2, 2007 09:09 PM
mattcivic
25
Oct 9, 2004 11:44 AM
