Problems with Tein Basic Suspension
Well today I attempted to lower my car again for the summer. I ran into a huge problem. The locking nut (bottom one) unlocks and moves freely but the top one doesnt. It wouldnt budge for anything in the world. Even using a breaker bar couldnt budge this thing.
Has anyone ran into this problem before? If so how did you correct it? Any ideas?
Thanks for your help!
Sounds like its siezed, Use lots of wd40 and/or PB blaster ( works great), and some heat wouldnt hurt too, take a torch to it for a very small amount of time, just enough to heat it up. If you presoak it in ANti-seize spray ( PB blaster or WD40), let it soak for 10 mins, then heat it up with the torch, that should do the trick to freeing it up.
hohiah
Aug 23, 2002 10:38 PM
