vtec head swap
Youll feel a big difference in the two . But not a tremendous amount of power. Maybe 10-15hp at most . I believe. There is no point in wasting your money on a Vtec controller. As far as my opinion goes. THERE JUNK !!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackmfoggie »</TD></TR><TR><TD CLASS="quote">Is it worth it such as the horse power. And if so can I use a vtec controller</TD></TR></TABLE>
no its not worth it, you will probably not notice any change in power and yes you could use a vtec controller if you wanted to
I beg to differ on not noticing any power change. Your saying that no boost vs. vtec boost you couldnt tell the difference.
If your using a vtec controller. Why would you want to turn the vtec lower to engage at a lower Rpm . When the vtec works on Oil pressure. And requires a certain Rpm range to fuction correctly. Turning it up higher is a waste if you ask me .
I have swapped a H23 dohc non vtec head on a F22 block . The swap is fairly simple. But I have never went from nonvtec to vtec. Nor have I swapped an h22 head on a f22 block . 92-97 h23 head will work for you . Youll need the Head, intake manifold, throttle body, Thermostat housing, F22 head gasket, p13 ecu, Crank pulley. and a few others.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord380whp »</TD></TR><TR><TD CLASS="quote">I beg to differ on not noticing any power change. Your saying that no boost vs. vtec boost you couldnt tell the difference. </TD></TR></TABLE>
yes thats what i am saying
if you go from non vtec to vtec... then you need to tap the block and head and put an external vtec pressure switch and run the oil lines. then rig up a vtec solenoid, run the wires to the right pinouts on the harness, and get a vtec ecu. it is def a pain in the rear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectTib »</TD></TR><TR><TD CLASS="quote">if you go from non vtec to vtec... then you need to tap the block and head and put an external vtec pressure switch and run the oil lines. then rig up a vtec solenoid, run the wires to the right pinouts on the harness, and get a vtec ecu. it is def a pain in the rear</TD></TR></TABLE>
woah, what?
external pressure switch? thats located on the solenoid which bolts to the cylinder head
oil lines? on sohc block/head oil feed for the head is already in the block
rig up a vtec solenoid? by "rig" do you mean bolt on with three bolts?
woah, what?
