Won't crank
Old May 27, 2007 | 10:21 AM
w3bcod3r's Avatar
Default Won't crank
1991 Honda Accord
listen... i'm gonna be short as possb.
pulled a plug out of distrubutor a night before (security reseasons!!... next morning forgot about it n tryed to crank it... ir ran for about 2 sec n died. reconnected the plug and tried to crank it again... nothing...
I know its either plugs, wires, distr. or crank sensor... question... opinion?
Old May 27, 2007 | 10:22 AM
accord380whp's Avatar
Default Re: Won't crank (w3bcod3r)
you getting any cels ?
Old May 27, 2007 | 12:10 PM
w3bcod3r's Avatar
everything seems to be in order... it feels like its not getting enough spark somewhere... hmmm... later
Old May 27, 2007 | 01:09 PM
Default Re: (w3bcod3r)
If it was the crank sensor. You would be getting a check engine light.
Old May 30, 2007 | 11:08 PM
w3bcod3r's Avatar
not always...
Old May 31, 2007 | 04:23 AM
JimBlake's Avatar
The title says "Won't crank" so don't waste time with plugs, wires, & sensors. Look at the starter motor, big-wire connections to the starter, & battery.
Does the small wire at the starter have battery voltage when you try to crank? If not, then look for flaky ignition switch or bad connections around there.
Old May 31, 2007 | 08:56 AM
Patman's Avatar
this is an interesting topic, whats generally the best thing to unplug under the hood for a simple un-startable car?
Old May 31, 2007 | 03:12 PM
JimBlake's Avatar
Default Re: (Patman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patman &raquo;</TD></TR><TR><TD CLASS="quote">this is an interesting topic, whats generally the best thing to unplug under the hood for a simple un-startable car?</TD></TR></TABLE>Anything that's simple is also gonna be simple for someone to re-connect. IF they know their way around the engine.
Starter signal wire?
Distributor gang-harness plug?
Fuel pump fuse?
With a little creativity, you could interrupt power TO the ignition switch with a hidden toggle switch somewhere that ONLY you know about.
SeanRK
Honda CR-V & Element
Dec 8, 2015 04:12 PM
Preludelearner
Mar 26, 2015 07:54 PM
aemintgsr
Nov 6, 2010 08:04 AM
rick_rabies
26
Apr 5, 2009 01:07 PM
