#1,3,4 NOT firing w/fuel and spark!
Old May 27, 2007 | 09:30 AM
kamakaze1's Avatar
Default #1,3,4 NOT firing w/fuel and spark!
my 99' civic ex was running FINE,put ITB's NEW head gasket and ARP head studs.the car is getting fuel because the cylinders that ARE'nt firing are wet with fuel.i pulled the #1 spark plug wire off and it's firing perfectly..........................WHAT is IT?
Old May 27, 2007 | 09:37 AM
Otherguy's Avatar
NASIOC.com
Default Re: #1,3,4 NOT firing w/fuel and spark! (kamakaze1)
where are you at in killeen?
Old May 27, 2007 | 09:39 AM
Otherguy's Avatar
NASIOC.com
Default Re: #1,3,4 NOT firing w/fuel and spark! (Otherguy)
hows the timing? Is this a d16y8?
Old May 27, 2007 | 09:40 AM
kamakaze1's Avatar
YES i'm in killeen,it's a Y7/Y8
Old May 27, 2007 | 09:47 AM
Otherguy's Avatar
NASIOC.com
Are your plugs fouled out?
Old May 27, 2007 | 03:40 PM
kamakaze1's Avatar
looking down into the cylinders looks like the pistons are wet causing the spark plugs to foul up.the only thing i can think of is the valves are either staying closed and NOT letting air in or open causing almost the same effect!
Old May 28, 2007 | 04:28 PM
Otherguy's Avatar
NASIOC.com
are you in the army? Give me a pm and I will give you my phone number and If I have time during lunch I can come look at your car. I work on fort hood
Old May 28, 2007 | 05:01 PM
cvkid15's Avatar
you need three things to start a car, fuel, spark and compression, check that if not then it could be the timing
Old May 28, 2007 | 05:36 PM
-JSpecEk*9-'s Avatar
Default Re: (cvkid15)
you changed the headgasket? did you set your base timing? the markns on the crank pulley?
Old May 29, 2007 | 08:31 AM
mikeycivic's Avatar
Default Re: (-JSpecEk*9-)
timing
tchandarlis
Sep 6, 2016 09:33 PM
SimplyTron
Feb 19, 2007 12:08 PM
robert_v
Nov 12, 2006 07:16 PM
ludetech
May 20, 2004 10:33 AM
g2turbo
Sep 17, 2003 08:31 PM
