Knock Sensor! Do the wiring connect at the top or bottom of the connector?
Old May 27, 2007 | 07:20 AM
JBirch_97Prelude's Avatar
Default Knock Sensor! Do the wiring connect at the top or bottom of the connector?
My Knock Sensor wire was pulled out from the connector. I can't seem to figure out which part of the connector to connector the red and blue wire.
Old May 27, 2007 | 10:08 AM
Default Re: Knock Sensor! Do the wiring connect at the top or bottom of the connector? (JBirch_97Prelude)
I switched them back and fourth and I am still throwing code 23. I even put electrical tape over the exposed wire and it continues to throw code 23 when I go over 3000 rpm's for more than 3 seconds.
Old May 27, 2007 | 12:47 PM
Anyone?
Old May 27, 2007 | 12:59 PM
cpmike's Avatar
the side nearest the clip.
when in doubt, use a new 2-pin plug and wire both pins together
Old May 27, 2007 | 01:03 PM
Default Re: Knock Sensor! Do the wiring connect at the top or bottom of the connector? (cpmike)
Thanks alot, what if it still throws a code? Could the Sensor have shorted out when I accidently knocked the wire out?
thebleek
Jul 30, 2008 08:20 PM
sir2sol
May 12, 2007 05:32 AM
Civiclx
40
Jun 8, 2006 11:04 AM
speshuled619
Jul 25, 2002 05:12 PM
