bleeding my coolant system in a dohc zc
i am going to be cleaning my iacv and fitv soon and i believe that i need to bleed the air out of my cooling system, right? i know i need to remove the radiator cap and let it run until it is at running temp, then i need to turn it off, replace the radiator cap and remove the bolt from the bleed valve, correct? but i dont know where to look. is it on the head anywhere? its a 88 crx hf w/ dohc zc swap. any help is appreciated.
the bleeder valve is on the upper radiator hose outlet on the engine - kind of behind and below the distributor - don't replace the cap - just shut it off, open the valve and fill the radiator with coolant until it starts seeping out the bleed valve without bubbles, then close the valve - fill the overflow bottle and be sure to turn the heater on to hot when it is warming up to get any air out of the heater - the OBD0 DOHC ZC doesn't have a FITV
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gRim06 »</TD></TR><TR><TD CLASS="quote">what does it have then? just the iacv?</TD></TR></TABLE>
yes
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">the bleeder valve is on the upper radiator hose outlet on the engine - kind of behind and below the distributor - don't replace the cap - just shut it off, open the valve and fill the radiator with coolant until it starts seeping out the bleed valve without bubbles, then close the valve - fill the overflow bottle and be sure to turn the heater on to hot when it is warming up to get any air out of the heater - the OBD0 DOHC ZC doesn't have a FITV</TD></TR></TABLE>
i cleaned my iacv last night then put it back on this morning, i connected the negative post and took the cap off, it was full to my surprise. when i tried to start my car it died likes it been doing,
this is what its been doing:
"in the morning when i start my car it dies, i can keep trying to start it without opening the throttle, then it idles @500 for a sec and builds up to 750 or 8, once it warms up and the needle passes the line, i can go without it dieing on me, but after i rev it or drive its idle bounces between 500 and 750, if its not warmed up well, it dies on me when i hold the clutch or stop. if its too cold in the morning, i have to open the throttle a lil bit for a min or two until it revs between 500 and 750."
Now, after the second time i started it didnt try to stay started, i had to give it immediate throttle to get it started, it died if i let off, so i had to hold for a min. then i let it rise from 500, very slowly to 750. when it was warm i turned it off, i didnt remember to leave the cap off and fill w/ coolant while the bleeder valve was open, when i started it nothing came out, now i know why
i turned it off and replaced everything and started it again, every time i start it it stayed at 500, it was already warm, it usually bounces, when it idle at 750 for a min i revved a lil, it died. i started it again and revved as lil as possible and it died again. i didnt know what to think, i took it for a drive and every time i rev it or drive, and let off the throttle completely it died, it drives fine in first and shifting, but if i hold the clutch and let off the throttle it dies, i parked it and it died. im gonna let it cool off for a while and bleed it again, filling it with water this time w/ the bleed plug off. also, i cant do anything w/ the heater b/c i have nothing but vents on my dash, no radio nothing, just ashtray and lighter. the defrost button works for the rear hatch window i've noticed, but i dont think it blows any air.
Do you or any body else know what my problem is? i'd appreciate any help. srry for the epic.
Modified by gRim06 at 3:47 PM 5/28/2007
i turned it off and replaced everything and started it again, every time i start it it stayed at 500, it was already warm, it usually bounces, when it idle at 750 for a min i revved a lil, it died. i started it again and revved as lil as possible and it died again. i didnt know what to think, i took it for a drive and every time i rev it or drive, and let off the throttle completely it died, it drives fine in first and shifting, but if i hold the clutch and let off the throttle it dies, i parked it and it died. im gonna let it cool off for a while and bleed it again, filling it with water this time w/ the bleed plug off. also, i cant do anything w/ the heater b/c i have nothing but vents on my dash, no radio nothing, just ashtray and lighter. the defrost button works for the rear hatch window i've noticed, but i dont think it blows any air. Do you or any body else know what my problem is? i'd appreciate any help. srry for the epic.
i bleed my coolant again, now it doesnt die as much but its still idles at 500 and builds up to 750 and bounces in between. anybody????
xlusiveracer
30
Feb 10, 2017 11:49 AM
