car won't start again...could it be the timing?
Old May 26, 2007 | 09:51 PM
go2sleep's Avatar
Default car won't start again...could it be the timing?
after replacing the disty with a reman. one, the car started up sputtering, as if it was misfiring, and then would die. i was able to start it up another 4-5 times but now, it just keeps cranking.
im thinking it could be the disty again.
i damaged my previous cap+rotor because the rotor screw came lose and was lodge between the rotor and the inner disty cover. could that have caused my timing to have skipped a tooth?
Old May 27, 2007 | 12:32 AM
MR_FIX_IT's Avatar
Default Re: car won't start again...could it be the timing? (go2sleep)
My old DA did the same thing............never could figure it out
Old May 27, 2007 | 08:55 AM
go2sleep's Avatar
bump for advice
Old May 27, 2007 | 04:15 PM
go2sleep's Avatar
car cranks and starts up. turns out, my timing is advanced but was irrelative to ...not having enough gas in the tank
Old May 27, 2007 | 06:08 PM
MR_FIX_IT's Avatar
Default Re: (go2sleep)
so what was the problem
Old May 30, 2007 | 11:43 AM
kenneyd's Avatar
Default Re: (Purple_GS-R)
my car did that before, and the replacement was bad, tried a friends and changed the plugs and it crunk right up. then tried the replacement and the original, and no crank.
Old May 30, 2007 | 12:53 PM
Crazydave's Avatar
Default Re: (kenneyd)
did you get the firing order correcT?
yo bj
Feb 2, 2011 05:54 PM
EJ ITO
26
Mar 22, 2007 05:41 AM
street_warrior_import
Jan 30, 2006 03:39 PM
hondaeg8
16
May 6, 2004 01:40 PM
thalwr1
Mar 17, 2003 06:24 PM
