96 integra running to rich!!!!! help?!
Old May 26, 2007 | 06:14 PM
96teggylsse's Avatar
Default 96 integra running to rich!!!!! help?!
i have a 96 integra ls se and its throwing the check engine light abd i cant figure out why?!!! i work as a mechanic at a shop here in town but i just cant get this one... there are no codes when i hook up the snap on obd 2 code reader but still check engine light i have reset it several times and in about 30 sec. i will come right back on and run way rich and misses a little not bad though!?!?!?!? i need help... i cant afford gas in my car when it gets 140 miles to half a tank! lol thanks ahead for any suggestions peace!
Old May 26, 2007 | 06:26 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 96 integra running to rich!!!!! help?! (96teggylsse)
Have you checked to make sure the stock computer is installed? Perhaps is was swapped to an OBD1 unit.
If it is the correct OBD2 computer, it could simply be failing.
Old May 26, 2007 | 06:30 PM
ya i thought that might be an issue but i got it off a old couple that kept it bone stock but i guess it could be failing i know they didnt mod it though.... i need to find some one with an obd 2 unit everyone here swaps to obd 1 though!!!!! thanks...
Old May 31, 2007 | 07:32 AM
Default Re: (96teggylsse)
any other ideas people?????
Old May 31, 2007 | 08:23 AM
Dogginator's Avatar
Daisy... Daisy...
Have you tried to pull the codes through the CEL by jumping the diagnostic connector?
Old Jun 7, 2007 | 09:53 PM
Default Re: (Dogginator)
ok so i pulled the codes through the cel and icame up with code 54... which is crankshaft fluctuation sensor... or somin like that.i havent looked into it to much but ive heard that it will make your car miss sometimes, but no one has said anything about it making it run rich. so i need to know if this will cause bad air/fuel ratio or if anyone has experienced prob. with this sensor or if you think my ecu is dicked ? thanks
Old Jun 8, 2007 | 04:07 AM
Dogginator's Avatar
Daisy... Daisy...
If it is missing, it is not burning the fuel and may appear to be running rich.
Old Jun 8, 2007 | 04:44 AM
1998b18c1's Avatar
check your distributor, pull the cap and see if it looks worn. also its going to run like a dog because its in limp mode....you need to address the cel concern asap.
how many miles do u have on ur ls?
Old Jun 8, 2007 | 08:12 AM
Default Re: (1998b18c1)
120,000 miles. its got a new dizzy complete so i think thats fine...i will check on that sensor later today... ive heard people get it caught in the timing belt when that change it so ill checkit out
Old Jun 9, 2007 | 11:15 AM
1998b18c1's Avatar
great you have under 150k, you now need to take it to an acura dealer...you have an emissions warranty extension--look at this THREAD https://honda-tech.com/zerothread?id=1936942
goodluck
Modified by 1998b18c1 at 1:20 PM 6/9/2007
Modified by 1998b18c1 at 1:21 PM 6/9/2007
Modified by 1998b18c1 at 1:22 PM 6/9/2007
mxracer420
Jun 1, 2009 01:01 PM
teggie253
Dec 14, 2006 11:23 AM
tannerhoops
Dec 11, 2005 07:18 AM
Archangel02150
Sep 4, 2004 09:34 PM
