Engine Check Light
Old Dec 13, 2006 | 10:24 AM
teggie253's Avatar
Default Engine Check Light
ok here it goes i bought a 96 integra with jdm ls swap and the engine light was on i also noticed there was an obd 2 to obd 1 conversion, i was thinkin maybe that could be it i only have about 70k on this thing everythings fine with the car no smoking everything idles fine does anyone know whats up or how i can get rid of it.... i would appreciate if someone could help me out thanks...
Old Dec 13, 2006 | 10:48 AM
street_bliss's Avatar
was the obd2 to one conversion just for the ECU?? or was the engine obd 1. Becuase if its still obd2 ecu you can get the code ran at auto zone for free to fid out what it is. If its an obd 1 computer you will need to find the little two prong connector that will be up by the glove box on the passsenger side and just jump the connector. So take either a paper clip or a wire and connect one side to the other. Yuor chech engine light will start flashing. Do a search on H-T for how to read the code and all the honda codes. it has been posted on here several times.
Old Dec 14, 2006 | 07:16 AM
teggie253's Avatar
Default Re: (fast_96gsr)
aye ill do that when i get a chance aye thanks alot man..
Old Dec 14, 2006 | 08:15 AM
Boots's Avatar
Default Re: Engine Check Light (teggie253)
i didnt know there was such a thing as a jdm ls swap...
Old Dec 14, 2006 | 08:27 AM
GolfIVTyBiggums's Avatar
Default Re: Engine Check Light (boots)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boots &raquo;</TD></TR><TR><TD CLASS="quote">i didnt know there was such a thing as a jdm ls swap...</TD></TR></TABLE>
I believe there is, however I also believe anyone who buys a LS swap from Hmotors assumes it is JDM while it is probably USDM.
Old Dec 14, 2006 | 08:32 AM
DC2.GSR's Avatar
Default Re: Engine Check Light (GolfIVTyBiggums)
i hate engine check lights!!
Old Dec 14, 2006 | 11:23 AM
akandok's Avatar
there are in fact JDM ls swaps. B18B
Find out what the code is and then we could help
demo024
Feb 17, 2011 03:17 AM
jlowellintegra
Oct 27, 2010 07:38 PM
hothondas
Aug 4, 2008 06:24 PM
imlachg1
May 5, 2004 12:50 PM
jeremy.
Aug 22, 2003 06:59 AM
