timing belt , 87 2.0 injected
Old May 26, 2007 | 03:49 PM
inthetriploop's Avatar
Default timing belt , 87 2.0 injected
Hi all,
I think the timing belt just went, I was going a steady speed around 70-80kph and I heard a backfire type noise and then my speed started decreasing, there was an existing problem something to do with a timing advance that made the rev fall if held at 2200rpm or a bit lower/higher, I had thought it was that, so I let go of the gas and pressed on it again, but it didn't work, speed and rev kept decreasing. When that didn't work I pressed in the clutch and then the engine stalled. The engine wouldn't start after that.
After opening up we saw that the timing belt was pretty loose. When it happened, I didn't hear any strange noise other than the backfire before the rev started going down. I didn't hear a bunch of terrible noise at all at any point. Is it safe to assume that the car is worth fixing (if everything is scrapped it's not really worth while)? Do I need a new head? Are my valves finished for sure? I was under the impression that there would be a lot of noise if that were the case, but then again my exhaust is pretty loud (need new manifold and also the muffler piece).
Anyone have this happen on a similar car (87 2L injected prelude)? Advice, tips? I don't know that much at this point.
Thanks for any help .. !!
Old May 26, 2007 | 04:19 PM
bluelude2.3's Avatar
Default Re: timing belt , 87 2.0 injected (inthetriploop)
All you really can do is take it to a good shop and have them look at it.
It might just be off a tooth or two.
Old May 27, 2007 | 02:30 PM
Default Re: timing belt , 87 2.0 injected (bluelude2.3)
Ok so two people helped me out and we changed the timing belt and the tensioner, the car started but now it doesn't sound or run the same as before. I guess I could be losing compression now.
94gsr_vtc
Nov 24, 2004 03:45 PM
Bictorious
12
May 5, 2004 07:56 PM
petrv
Mar 1, 2004 10:32 AM
petrv
Mar 1, 2004 09:56 AM
CRzex
Feb 24, 2002 07:17 PM
