question about my MINI ME
Old May 26, 2007 | 03:37 PM
freddysEF's Avatar
Default question about my MINI ME
Ok im almost done doing my swap but i have a question, did you guys use the same throttle cable or use a different one??
also i heard that i dont need to use the oil pressure socket on the head, the green socket right next to the Vtec
Old May 26, 2007 | 04:14 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: question about my MINI ME (freddysEF)
you can bypass it but if you don't and use the P28 ECU it will throw a code and won't activate VTEC. I have a few for sell if you need one.
Old May 26, 2007 | 04:41 PM
electric_rex's Avatar
Default Re: question about my MINI ME (HondaPartsHero)
for SALE
Old May 26, 2007 | 04:56 PM
freddysEF's Avatar
ok so oil pressure socket will throw a code and wherer would if be connected too?? so what about the throttle cable???
Old May 26, 2007 | 09:59 PM
freddysEF's Avatar
Old May 26, 2007 | 10:47 PM
biggee's Avatar
use and EF si throttle cable....
as for your oil pressure, are you talking baout that plug that you were supposed to remove in the block before you installed the head?
Old May 27, 2007 | 06:40 PM
freddysEF's Avatar
Default Re: (biggee)
no its the green socket thats right nexts to the Vtec
Old May 27, 2007 | 08:05 PM
njn63's Avatar
Default Re: (freddysEF)
What ECU are you using? There is nothing to connect it to on a PM6. On a p28 you have to connect it or it'll throw a code.
LShatchie
19
Oct 3, 2006 07:04 PM
asubennett
Apr 14, 2006 03:57 PM
BoostedsiR
Nov 8, 2003 10:56 PM
311
Oct 10, 2002 10:01 AM
Houston Hatchback
Aug 24, 2002 06:03 PM
