Sloppy shifter
Old May 26, 2007 | 10:58 AM
honda_coupe's Avatar
Default Sloppy shifter
My stock Shifter is really sloppy when in any gear... if its in any gear and you move it side to side it moves like its in Neutral.. Is this because i need new bushings like Polyurethane like you would get with an after market short shifter? Or is it something to do with the shift linkage or tranny?
Old May 26, 2007 | 11:19 AM
Cookie's Avatar
Default Re: Sloppy shifter (honda_coupe)
Has anyone ever had your linkage down or unbolted?
I would get the car up, with car stands, safely blocked and check and see if it is properly fastened by just grabbing it and seeing if how much play you have.
But, by what you are saying, I would maybe go in to this with the thought of replacing with poly bushings or just replacing the stock beat bushings for new ones. Depending on your budget.
The linkage should never move like you say it is.
Old May 26, 2007 | 01:04 PM
EKidd's Avatar
Default Re: Sloppy shifter (Cookie)
I have the same problem as the OP.. I was just going to jack the car up, get under it, and see if my linkages were loose or not
Old May 26, 2007 | 01:52 PM
Team RS2's Avatar
Default Re: Sloppy shifter (EKidd)
bump mine does the same thing its a real bitch to tell if you are in nuetral or not lol
Old May 26, 2007 | 02:08 PM
civicduty's Avatar
Default Re: Sloppy shifter (Team RS2)
it's your bushings... all stock civic shifters are pretty sloppy and have a lot of play. swapped out my stock bushings for some poly's and a short shifter few years back and everything is much crisper.
Axle Raynes
Jul 15, 2009 06:54 AM
DOUBLExDEUCEx22
Oct 25, 2008 09:44 AM
elmalouno
May 2, 2008 08:37 AM
DirTyPreTTyThinGs
Aug 15, 2007 08:35 PM
DI9ITAL
Feb 8, 2003 09:09 PM
