whats the difference vs ekk1/2 mounts
Old May 26, 2007 | 08:41 AM
dropped like its hott's Avatar
Default whats the difference vs ekk1/2 mounts
what is the difference between the two
Old May 26, 2007 | 09:56 AM
ekb16's Avatar
Default Re: whats the difference vs ekk1/2 mounts (dropped like its hott)
Hasport would like to announce the release of the new EKK2 mount kit. This kit is designed to be use with the EG crossmember, steering rack and lower control arm. This allows the engine to be mounted rearward another 2 inches and up about an inch. This ideal for drag racing as it straightens the axles and road racing becuase it moves engine weight rearwards.
The kit has two sets of mounting holes so that the engine can be mounted slightly lower so that the P/S pump can be used without modifying the hood. Even with the engine mounted in this lower position because the oilpan is so close to the front wheels ground clearance is still excellent.
http://www.k20a.org/forum/showthread.php?t=21985
http://www.k20a.org/forum/show...+ekk2
compdog694u
Dec 12, 2006 12:28 PM
brian g
May 1, 2005 03:13 PM
lsvtec2.0
39
Feb 24, 2005 08:55 PM
Tyson
13
Dec 24, 2003 10:25 PM
EGtoR
Dec 20, 2002 06:55 AM
