What VSS To Get? OBD0 B16. Do D16 vss's work?
So aparently when I was doing my tranny swap I snapped my vss
The motor is a obdo b16 with the cable vss. Kind of an odd looking unit
Since I snapped the cable, whats the easiest cheapest replacement I can swap in?
If you broke the cable -purchase a cable for your model car (regradless the motor).
If you have a 92+ you shouldn't have a cable though -wrong forum or was it not the cable that you broke?
Thats what I thought to, but theres more to it I guess
I broke the cable because I COULD NOT REMOVE it from the tranny, I removed the little c-clip like Ive done on other cars, and the dam thing just wouldnt yank out
So I dropped the trans wit it connected trying to be careful but it broke anyways
So, I dunno if I can even get this dam thing outta there....
What should I do?
What should I do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS »</TD></TR><TR><TD CLASS="quote">But I couldnt even get the cable out of my VSS, then it snapped, what am I supposed to do?</TD></TR></TABLE>
Maybe you didnt read the question bone, I simply removed the c lip and tried to pull the vss cable out, didnt budge so I left it, dropped the tranny with it connected and it snapped
I can probably just undo the bolt on the VSS unit thing and the whole unit comes out doesnt it?>
d series **** will work...
as far as removing the cable vss from the trans...I don't have one in front of me, but even though it is cable isn't there still a 10mm bolt you have to remove to take off the vss housing from the trans?...sorry if I'm wrong on that...I'll go look in storage and see if I have any cable trans kicking around and see how to remove the cable/housing
but now my question is this...since you were doing a transmission "swap" why are worried about getting the cable out of the transmission that came out of the car? aren't you putting a different one back in? if so...you probably need just the cable right?
PINKS
14
May 28, 2007 09:14 PM
coot_er
13
May 25, 2004 07:02 PM
bardo
Mar 10, 2004 05:36 PM
Desperado
Feb 21, 2003 08:10 PM
