a couple ej questions
Old May 26, 2007 | 06:48 AM
EJ8 Kenobi's Avatar
Default a couple ej questions
Hey guys, couple questions. First, are the tail light bulb harnesses the same on all 96-00 year civic coupes? And the front suspension forks that connect the strut to the lca are those all the same between 96-00 2dr and/or 4dr?
Old May 26, 2007 | 07:10 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: a couple ej questions (EJ8 Kenobi)
The suspensions are all the same except for the ex/si getting different front LCA's for the sway bars.
The tail-light harnesses are differen't between 96-98 and 99-00. The turn signal bulb is differen't.
It's still compatible between generations, it's just hard to find the amber bulb for the 96-98 harness. I usually find them at autozone.
Old May 26, 2007 | 07:13 AM
EJ8 Kenobi's Avatar
Default Re: a couple ej questions (ek forever guy)
Thanks man,
So if I have a 2000ex my front suspension forks will not be compatible with say a 97 dx? but it would a 97 ex.
Old May 26, 2007 | 07:16 AM
Ek Forever y0!
They would be compatible, you just wouldn't have mounting holes for a sway bar.
Old May 26, 2007 | 07:19 AM
EJ8 Kenobi's Avatar
the sway bar mounts to the forks? or are you say that the LCA's are not the same but the forks don't matter
Old May 26, 2007 | 07:22 AM
Ek Forever y0!
Doh, nvmd, i thought you said Lcas.
No, all the forks are the same I belive.
Ex civic
http://www.hondaautomotivepart...81%29
Dx/cx civic
Same part #
Old May 26, 2007 | 07:43 AM
EJ8 Kenobi's Avatar
ok cool, I'm just double checking before I wrench away at the junkyard
Old May 26, 2007 | 06:06 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">The suspensions are all the same except for the ex/si getting different front LCA's for the sway bars.
It's still compatible between generations, it's just hard to find the amber bulb for the 96-98 harness. I usually find them at autozone.</TD></TR></TABLE>
To clarify:
The '96-'98 coupe taillight harness IS NOT the same as the '99-'00 coupe taillight harness. They are interchangeable, but if you have a '96-'98 harness on a '99-'00 taillight, you will likley have trouble finding the amber bulb to fit in the '96-'98 turn signal socket on the harness.
Old May 26, 2007 | 07:20 PM
Team RS2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">They would be compatible, you just wouldn't have mounting holes for a sway bar.</TD></TR></TABLE>
sway bars mount to the LCA not the suspension forks
Old May 26, 2007 | 07:30 PM
Ek Forever y0!
Default Re: a couple ej questions (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">
sway bars mount to the LCA not the suspension forks </TD></TR></TABLE>
Umm, I already corrected myself. Thanks Captain Obvious. You saved the day again with another useful post.
rexman2002
Suspension & Brakes
Jul 6, 2009 11:12 AM
eklum
Northern California (Sales)
Jan 3, 2007 03:53 PM
ekim952522000
22
Nov 24, 2006 02:07 PM
EL Vap133
15
Apr 14, 2005 05:26 PM
SRCivic97
Jan 28, 2005 12:15 PM
