GSR Help???
Old May 25, 2007 | 04:24 PM
EJ1 Type Slow's Avatar
Default GSR Help???
hey my cousin has a 96 gsr usdm and he is going to buy some stuff and wants to know bout how much power he will have....he is gunna buy:
Skunk2 intake manifold
skunk2 throtle body 65mm
Cold air intake k&N
dc header
HONDATA S200
skunk2 megapower n1 exhaust
and a hi flo cat
and he is going to have it proffessionally tunned and chipped ....everything is being shipped now and he has a stage 3 ACT clutch and 8 lb flywheel already in......and opinions about power ...how much to wheels and how much to crank and i think 205 or so but not sure...
Old May 25, 2007 | 04:25 PM
pdotjones's Avatar
Default Re: GSR Help??? (Eg_k20)
dyno......
Old May 25, 2007 | 04:31 PM
aint got dyno money that **** cost bread so im just asking around wut people think
Old May 25, 2007 | 05:25 PM
[ iLL ] iNt3GrA's Avatar
Default Re: (Eg_k20)
if you dont have money to run on a dyno how are you going to tune the car right?
Old May 27, 2007 | 12:07 PM
doood's Avatar
been there done that
Default Re: ([ iLL ] iNt3GrA)
150-160whp
that's right
Old May 27, 2007 | 12:14 PM
SleeperGSR's Avatar
Default Re: GSR Help??? (pdotjones)
i don't know how you could buy looks like over 1000$ worth of parts for you car and then be stressing about paying for a dyno. **** costs like 20$ at the place i go to.
Old May 27, 2007 | 12:33 PM
LastDetail's Avatar
Default Re: GSR Help??? (SleeperGSR)
Are you planning to do any head work? No cams or valve train? It seems like there is gonna be a helluva lot of air coming in which will help your top end a little, almost no backpressure which will sacrifice your low end torque, but the engine itself is going to be restricting the flow.
Just my $.02
Old May 27, 2007 | 01:45 PM
numbnuts22715's Avatar
you have to tune hondata s200, youll get a printout with the numbers when youre doing that.
If you're not going to tune it, dont get the s200, there's almost no reason anyway.
Old May 27, 2007 | 04:23 PM
EddieLe76's Avatar
hm...205? thats kinda much dont you think??
Old May 27, 2007 | 04:41 PM
dirtygsr94's Avatar
Default Re: GSR Help??? (EddieLe76)
looks like your just shifting the powerband up high and killing your midrange. you need higher comp pistons and cams etc to really make use of that stuff. i say what the other guy already said 150-160 maybe. butt dynos are worthless. and for 205whp NA you need a lot more work.
Old May 27, 2007 | 04:45 PM
TurboGS-R's Avatar
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">you have to tune hondata s200, youll get a printout with the numbers when youre doing that.
If you're not going to tune it, dont get the s200, there's almost no reason anyway.</TD></TR></TABLE>
Exactly.. and to the person who said dynoing costs $20, unless you have the "hookup", it's usually more like $150 per hr.
Old May 27, 2007 | 06:08 PM
SleeperGSR's Avatar
Default Re: (TurboGS-R)
Ummm...sorry 25$ my bad. here is the shop.
http://www.bishopmotorsports.com/our-shop/ scroll down to standard dyno rates.
Old May 27, 2007 | 06:19 PM
crispy93's Avatar
349587.43 hp with approx. 234501 ft/lbs
and if youre not going to tune it, why have the s200?
BMo Tuning
13
Feb 7, 2008 12:42 PM
EJ1 Type Slow
Jun 16, 2007 10:28 PM
spunky424
25
Apr 2, 2004 05:20 PM
tSuperbike69
Apr 25, 2002 06:13 PM
maggsgsr
Jan 25, 2002 12:46 PM
