Already searched..need your help!!
Old May 25, 2007 | 01:00 PM
adam4lsu's Avatar
Default Already searched..need your help!!
couple days ago i was swappin out the stock radio/casette on my 92 civic ex for a cheap aftermarket. After i got all the wires matched i was putting it into the dash when i accidently i touched a piece of bare wire on my ground constant wire on a screw in the dash..sparks flew and my cig lighter, stereo, climate control has no power anymore...i checked all fuses everything looks good but still no power. I have no idea what the problem could be ..any suggestions?
just a note: it was the ground constant wire on the center console wire harness that touched the screw
Old May 25, 2007 | 01:06 PM
B16b-EJ8's Avatar
Default Re: Already searched..need your help!! (adam4lsu)
Next time disconnect your battery when working with the electrical...double check those fuses, i bet you blew one of them for sure.
Old May 25, 2007 | 01:27 PM
xtegb16x's Avatar
Default Re: Already searched..need your help!! (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Next time disconnect your battery when working with the electrical...double check those fuses, i bet you blew one of them for sure.</TD></TR></TABLE>
Old May 25, 2007 | 03:23 PM
gone2m's Avatar
New User
Did you check the fuses under the hood? Most likely its one of those.
Old May 26, 2007 | 11:20 AM
adam4lsu's Avatar
Default Re: Already searched..need your help!! (gone2m)
every fuse in the car has been checked and double checked..cant understand why im not getting power to anything?
Old May 26, 2007 | 11:23 AM
Winlight's Avatar
it is either a fuse or a ralay
Old May 26, 2007 | 11:41 AM
Cookie's Avatar
Check ALL other wires AGAIN! Reset your ECU. Pull that fuse, in the engine bay,,, check it,,, Hold out for 15 seconds, place back in and retry. See if that works.
Old May 26, 2007 | 12:10 PM
adam4lsu's Avatar
Default Re: Already searched..need your help!! (Cookie)
prolly gunna get nailed for this lol..how do I reset my ecu?
Old May 26, 2007 | 12:15 PM
Cookie's Avatar
Pull the fuse for 15 seconds.
You will notice a little seat of-your-pants performance difference too!
Good anti-theft devise, too.
Old May 26, 2007 | 12:17 PM
adam4lsu's Avatar
gotcha..thanks
hondaproof
Oct 10, 2012 09:12 AM
ZOMBIEKILLER
Audio / Security / Video
Feb 24, 2008 07:14 PM
BLUE EH3
15
May 2, 2006 02:42 PM
shivern
Jan 3, 2005 09:18 AM
DAYUIZ
10
Apr 17, 2004 07:04 PM
