deck smoked?
Old Jan 1, 2005 | 04:14 PM
shivern's Avatar
Default deck smoked?
ok so i checked and hooked up the constant and the switched, and the ground correctly. then i reconnected the battery and turned the key just to check out the deck, to my suprise it started to smoke(not very much), so i turned it off really quick. I went back and checked my wiring and its all correct.
after examining the diagram on the new deck it says there should be a filter between the stock ground wire and the deck ground wire somewhere. could this be the reason is smoked.
oh ya it also says this on the deck "CAUTION: 12V NEGATIVE GROUND"
can anyone explain this too me? any reasons or what?
Modified by shivern at 5:43 PM 1/1/2005
Old Jan 2, 2005 | 11:34 PM
b-power's Avatar
Default Re: deck smoked? (shivern)
did you use a wire harness?
Old Jan 3, 2005 | 07:44 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shivern &raquo;</TD></TR><TR><TD CLASS="quote">ok so i checked and hooked up the constant and the switched, and the ground correctly. then i reconnected the battery and turned the key just to check out the deck, to my suprise it started to smoke(not very much), so i turned it off really quick. I went back and checked my wiring and its all correct.
Modified by shivern at 5:43 PM 1/1/2005</TD></TR></TABLE> What kind of "deck" is it? I don't know why you would need a "filter" on the ground wire, and all HU, "decks" will say 12v neg. ground, if they are for cars that are 12v and the batt. neg. is grounded, there are,or were 12v pos. grounded cars and there are 24v cars.
I would recheck the wiring, pay attention to the speaker wiring, and if you seen smoke come out of your HU its not a good thing, damage has already been done 94
Old Jan 3, 2005 | 09:18 AM
shivern's Avatar
Default Re: deck smoked? (fcm)
Very dumb mistake, i figured the all black wire in the stock wiring harness would be the ground, never going to make that mistake again. deck still works tho =/ although kinda sketchy at times
blackk20dc5
Feb 11, 2010 06:33 AM
shivern
10
Jan 2, 2005 09:31 AM
Kavehman
Audio / Security / Video
Oct 30, 2004 05:44 PM
DAYUIZ
10
Apr 17, 2004 07:04 PM
azn_outlaw
Aug 13, 2003 11:02 PM
