Can you remove the IAT sensor?
Old May 25, 2007 | 09:23 AM
TopEndUSA's Avatar
Default Can you remove the IAT sensor?
Can you remove the IAT sensor? If so, is there a specific way. Thanks
Old May 25, 2007 | 11:53 AM
TopEndUSA's Avatar
Default Re: Can you remove the IAT sensor? (MardreRacing)
bump
Old May 25, 2007 | 12:05 PM
civicstar's Avatar
wat yr and wat engine? if its the ones on the manifold, from obd0-obd1, u have to use a big screw driver and press down really hard, be sure not to strip it, if u want to get more torque, clamp it with a vice grip and press down hard and turn
Old May 25, 2007 | 01:43 PM
TopEndUSA's Avatar
Default Re: Can you remove the IAT sensor? (civicstar)
It's a H22a4, but I'm running it like a OBD1. Does the sensor have to be plugged up, or can I eliminate it with the AEM EMS?
Old May 25, 2007 | 03:16 PM
arc_55's Avatar
why would you even want to do that? Also if you want to remove it use a screw impact driver.
Old May 25, 2007 | 07:18 PM
TopEndUSA's Avatar
issue resolved
Old May 26, 2007 | 08:27 PM
arc_55's Avatar
mine sharing what the results were?
Benevolent27
Jul 12, 2010 01:26 PM
peAches yO
Nov 9, 2009 08:05 AM
b20beast83
Jul 21, 2008 08:41 PM
BadAndyGoodPizza
May 3, 2006 08:13 AM
Westrock2000
May 19, 2003 06:02 AM
