JG EDELBROCK MANIFOLD
Old May 24, 2007 | 05:07 PM
Curt91's Avatar
Default JG EDELBROCK MANIFOLD
Sup' every one just put in a JG Edelbrock intake manifold the instal went in pretty good but Im having an IAC problem. Its on a manly stock b16 A2 in an 1999 Civic Si. I tryed swaping IAC's with another buddy and still no change. When the car is cold it revs between 2100-2500 rpm. When it warms up the idel will drop and rev no less between 1600-1700RPM. I check for leaks useing Acetylene and everything was fine . Any one got any ideas would be great help thanks !!!!
Or experience installing this type of manifold.
Old May 24, 2007 | 05:22 PM
Luserkid's Avatar
Default Re: JG EDELBROCK MANIFOLD (Curt91)
Sounds like a vac leak if its that high. Did you replace the intake manifold and throttle body gasket?
Lilsoldierbenny
Apr 16, 2010 07:27 AM
CountDracura
Mar 24, 2009 12:56 PM
jdmeg61
Oct 29, 2006 08:12 PM
