ECU'S WHICH ONE!!!!
Old May 24, 2007 | 03:54 PM
stock ek's Avatar
Default ECU'S WHICH ONE!!!!
ok so im putting my turbo kit together and im stuck on my injectors or my ecu so which ecu do you guys think is the best hondata, crome. or uberdata, im soo confused on which one to get, by the way its a d16y8 with 7psi. and injectors which ones and size and what is a resistor box, please help. thanks guys
Old May 24, 2007 | 03:58 PM
alacard's Avatar
Default Re: ECU'S WHICH ONE!!!! (stock ek)
First of all hondata, crome, and uberdata are different programs for tuning an obd1 ecu. They are not each a kind of ecu. To use any of those, you will need an obd1 ecu...for your situation you will want a p28 ecu which came off of the 92-95 ex civics. You will also need an obd2 - obd1 conversion harness. From there you will need to get it chipped with a basemap for your situation, and then baby your car all the way to your tuner who will set you up.
Old May 24, 2007 | 04:13 PM
doood's Avatar
been there done that
Default Re: ECU'S WHICH ONE!!!! (alacard)
find a tuner and follow their advice
alecrich22
Engine Management and Tuning
Mar 28, 2014 03:26 AM
Milab21
Jan 14, 2009 06:18 PM
BlackRocket
Jul 10, 2007 03:37 PM
brad98_teg
Dec 8, 2005 04:25 PM
otakueric
10
May 22, 2004 06:07 PM
