ctr piston help!
so iam going to be doing bottom end work here with in the months ....but i have a few questions i need answered before i can get going with it....so i was wondering if there is any way i can stay with a stock bore of 81mm cause i really dont wanna pay for the work for someone to oversize it to 81.25. Also will the pistons i plan on getting the ctr pistons be okay with my head? i have a b18c1 engine so yeah. Also if i do have to bore it out bigger will i have to do any work on the head because of the bigger pistons? Another question is will i also need to get new injectors or will i good tune solve that problem?
also
http://cgi.ebay.com/ebaymotors...ZWDVW
check the link tell if u think i should get this...everything looks good but the pistons are not a acutally honda brand so idk just check and tell me what u think i should do i need some help on this one
also
if the cylinder walls are still in good condition all they may need is a fresh hone to clean them up so you can stick with the stock bore size.
are you really set on ctr pistons? look into jdm p73's or p30's as alternatives .
wont i make more power with the ctrs? yeah ill just get it horned out then i didn't realize that thanks.....so did any of yall check out that link on that ctr piston seat? and if i should get it even tho its not honda made pistons?
s2s2 or maybe stage 1 not sure yet...but headwork is not till later...i just wanna get my bottom end built up cause right now my engine has 162k its time for a rebuild so i might as well get some good parts in there
http://www.zealautowerks.com
much more accurate than most online calculators. but these numbers should still only be used as general estimations.
stock injectors are good up to ~190whp. possibly more with a bump in fuel pressure but you're just making things work harder.
find a tuner and see what they recommend for tuning
how much whp do you think i could make with p30s and with new rod bearings,main bearings,and thrust bears...and like new rod bolts. and tuned
just with that bottom end work how much whp do you think i will maybe make like 165 or so?
yeah i guess we will just have to see... do you think i would be save buying one of those kits that comes with all the bearings and stuff rings and washers....when the pistons are not honda made?
