CEL light on
i dont think there is a code 26 recount the lights, and here
http://www.allmotorhonda.com/techpages/codes.htm
It would blink the slow ones first, go check again, you may be throwing a 17, because its easy to mistake the last slow flash as one of the single's flashes, rather than 10. THis would be VSS ( vehicle speed sensor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">It would blink the slow ones first, go check again, you may be throwing a 17, because its easy to mistake the last slow flash as one of the single's flashes, rather than 10. THis would be VSS ( vehicle speed sensor)</TD></TR></TABLE>
That makes more sense...
Look at the top of the transmission under the air intake arm. There is a sensor in the top of the transmission. It has a 3 plug connector, and there should be a 10mm bolt holding it in. You take that out and find a new one at a junk yard. But do more testing before you go throwing money at the problem.
pricey2010
May 5, 2010 11:33 AM
bright rider
11
Feb 28, 2007 12:43 PM
