Broken Timing Belttttttt
Old May 24, 2007 | 12:34 PM
CodyC142's Avatar
Default Broken Timing Belttttttt
Before anyone flames, I tried to search but my computer wont allow it to finish searching, it just spins and spins.
I was driving to work today in me 93 Si. And the timing belt snapped.
Is the d16z6 a non interferance motor? Or do I have to start looking for a new head? I wasnt in vtec when the belt broke, I was just cruising @ about 3000 rpms.
Any help would be GREATLY appreciated
TIA!
Old May 24, 2007 | 12:38 PM
pdiggitydogg's Avatar
More than likely, you broke some ****
Pull the head
If youre lucky, you need new valves...
(my belt skipped once, and I had to replace the valves)
Old May 24, 2007 | 12:50 PM
S2K81's Avatar
Default Re: (pdiggitydogg)
Bent valves for sure.. That's almost guarantee'd.
Old May 24, 2007 | 12:55 PM
hifonics's Avatar
Default Re: (S2K81)
i snapped a timing belt now am looking for a new head for my GSR
CodyC142's Avatar
Default Re: (S2K81)
Ok. I have a spare head from another d16z6. Its a different year motor though. I dont think this will matter but just wanted to make sure it was a slap on and go.
Nothing will need to be modified or changed?
Looks like Ill drive to the city bright and early and get a head gasket in the am, then pull the head off
Old May 24, 2007 | 12:57 PM
I-4's Avatar
I-4
That's why you do the friggin 100,000 km service.
Old May 24, 2007 | 12:59 PM
CodyC142's Avatar
Default Re: (I-4)
if I wanted to her someone give a lecture, Id go ask my mother.
Old May 25, 2007 | 10:35 AM
Crispy's Avatar
Default Re: (CodyC142)
you MIGHT have gotten lucky. I snapped a timing belt at about 4 grand tuning the car, didnt damage a thing. I have no idea how though, and it was on jackstands.
Old May 26, 2007 | 03:13 AM
jayjay's Avatar
Default Re: Broken Timing Belttttttt (CodyC142)
I can tell you from experience. I have had 2 motors break timing belts.
first was a DOHC zc. I was on the highway soing 65 when the timing belt shredded. I took the head off because I was worried about bent valves. Took it to a head shop locally and the guy was like "I can't understand this!" none of the valve had bent. They were all 100%, straight and true.
second was a Ls. Coming to a red light. About 30mph. The belt breaks. Not wanting to spend the time pulling the head. I took a chance and put a new belt on. Motor still runs today. Just like normal.
So I'ld say, maybe you can get lucky. Maybe the third time is the last for me.
You have a 50/50 chance.
Old May 26, 2007 | 03:48 AM
geebs's Avatar
Default Re: Broken Timing Belttttttt (jayjay)
i had an integra ls come into the shop for a broken timing belt/no start... pulled the head nothing was wrong with it.. so put it all back together and it fired right up and ran correctly
Old May 26, 2007 | 04:15 AM
g23_ej1's Avatar
Default Re: (Crispy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crispy &raquo;</TD></TR><TR><TD CLASS="quote">you MIGHT have gotten lucky. I snapped a timing belt at about 4 grand tuning the car, didnt damage a thing. I have no idea how though, and it was on jackstands.</TD></TR></TABLE>
tuning on jackstands? woah
as far as something happening, my friends old lude vtec belt broke twice on him.. first time he fixed it and ran like normal.. 2nd time i was drving from a road trip and it broke, replaced it and drove it home with no problems..
on the other hand ive seen when they break and the bend the **** out of valves and do damage.. i guess you could always just replace the belt and if it runs like ****, take the head off.. you're going to replace the belt anyways, so stick it on and try it out.. you might've gotten lucky
Old May 26, 2007 | 09:43 AM
Crispy's Avatar
Default Re: (g23_ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g23_ej1 &raquo;</TD></TR><TR><TD CLASS="quote">
tuning on jackstands? woah </TD></TR></TABLE>
*shrugs* that was one of the safer moments on this project unfortunatly.
Old May 30, 2007 | 11:48 AM
kenneyd's Avatar
I have a 90 teg, the belt broke driving about 35 mph, put on new belt, no bent valves or nothing wrong.
Old May 30, 2007 | 11:51 AM
fmrprojects's Avatar
just put another timing belt on and do a leak down test and see if anything is bent. if you get alot of leakage then you have bent valves. i replaced 2 belts on a LS motor that snapped and everything was okay still. just check it first, doesnt hurt. if nothing is bent you save some money
Old May 30, 2007 | 12:15 PM
perpetualburn's Avatar
Can you tell if your timing belt was just recently changed? I bought the car second hand..
Old May 30, 2007 | 12:18 PM
Discosteak's Avatar
Default Re: (I-4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I-4 &raquo;</TD></TR><TR><TD CLASS="quote">That's why you do the friggin 100,000 km service.</TD></TR></TABLE>
your doing your timing belt about 50,000 km early. its more like a 150,000 km service or 90,000 miles
accord2civic2prelude
Jan 22, 2012 03:17 PM
thunderboy
Aug 25, 2008 04:19 PM
typeRobtypeS
Jul 5, 2006 08:17 PM
northside856
May 22, 2005 01:03 PM
Jester88Si
Apr 22, 2005 08:13 PM
