accord EX 97 problem
Old May 24, 2007 | 02:33 AM
hema_f117's Avatar
Default accord EX 97 problem
i have a bounce RPM from 1000 to 1500 problem
they told me u have to cleat IACV and FITV and i did clean it very well
firt it was happining sometimes
now its alwayes comes
what is the problem can some one help
Old May 24, 2007 | 04:39 AM
TheMuffinMan's Avatar
He knows where you live!
I'm guessing at Idle?
Have you played with the Idle Adjustment ****?
Old May 24, 2007 | 08:59 AM
twkdCD595's Avatar
Default Re: accord EX 97 problem (hema_f117)
Check for any vac. leaks that you may have from lines getting knocked loose or deteriorated from age or whatnot.
Also you could try pulling your egr valve off and seeing if it was clogg'd. It can also cause a funky idle.
Your getting no codes (check engine) lights I asume?
Did you test the IACV and FITV to check to make sure they are still working while you had them off for a cleaning?
Just some thoughts.
Old May 24, 2007 | 04:47 PM
hondadude's Avatar
Burp any air out of the coolant system thru the bleed screw at the T-stat housing; Then turn in the screw under the lid of the FITV a couple turns.
Make sure there is a little slack in the throttle cable
Old May 25, 2007 | 09:49 PM
hema_f117's Avatar
Default Re: accord EX 97 problem (twkdCD595)
yes i did
how can i adjust it back to the normal case ?
Old May 25, 2007 | 09:50 PM
hema_f117's Avatar
Default Re: accord EX 97 problem (hondadude)
i changed them after i cleaned them
and also the same
bacuh
Jun 13, 2015 02:46 PM
busha61067
Feb 13, 2010 09:00 AM
A2brb
Sep 30, 2009 01:55 PM
aZnAcCoRd02
Apr 2, 2008 05:28 PM
rideredorgohome
May 6, 2003 02:41 PM
