wheres a good place to order parts??
Old May 24, 2007 | 12:39 AM
killingtwobirds's Avatar
Default wheres a good place to order parts??
iam looking to buy engine parts pistons rods, valves, valve springs, camshaft the hoooooolleee shaaabang well thanks for the help
Old May 24, 2007 | 12:46 AM
CHK4TIX's Avatar
Default Re: wheres a good place to order parts?? (killingtwobirds)
Do you want OEM or aftermarket parts for a specific type of build (turbo/NA)?
Old May 24, 2007 | 12:49 AM
for turbo sorry for got to add that part in
Old May 24, 2007 | 12:57 AM
i found these pistons and rods and i was wondering if they were the right ones
RODS http://www.jegs.com/webapp/wcs...64_-1
Pistons
http://www.jegs.com/webapp/wcs...21_-1
witch one should i get does the weight matter?
Bore: 87.00mm (3.425'')
Stroke: 3.571''
Rod Length: 5.630''
Pin Diameter: .866''
Compression Height: 1.220''
Dome Volume: -7cc
Weight: 328 grams
Compression Ratio: 9.0
or
Stroke: 3.571''
Rod Length: 5.630''
Dome Volume: -7cc
Weight: 331 grams
Old May 24, 2007 | 09:18 AM
anyone?
Old May 24, 2007 | 04:01 PM
bump
Old May 24, 2007 | 04:44 PM
Rosko's Avatar
Default Re: (killingtwobirds)
try http://www.laskeyracing.com
ashb82
Jul 7, 2022 12:51 AM
bukydc5
Aug 6, 2008 02:17 PM
BlkChryKord
Nov 6, 2006 11:35 AM
lsturbo*
Sep 16, 2006 05:24 PM
turbo sol
Nov 18, 2002 05:08 PM
