EK fogs on a EG
Old May 23, 2007 | 09:10 PM
Jdm_Eg686's Avatar
Default EK fogs on a EG
So i just got done installing Ek fogs on my wifes, 00 civic Ferio. And then i
read a post on here about installing them on a EG....I love the EK fogs on a EG
There will probably be alot of modifications needed, but my question is. Will
the Wiring harness work on my EG? or do i need the EG harness to work. I had
eg fogs but they were stolen and im left with the plug things in the fuse box.
thanks
-josh
Old May 23, 2007 | 09:12 PM
bpr0422's Avatar
Default Re: EK fogs on a EG (Jdm_Eg686)
lights are all wired up the same..
there is a + and a ground.
run power through it and it lights up.
just mounting it on ur eg bumper will be fun.
can't help you with that tho.
Old May 23, 2007 | 09:21 PM
Jdm_Eg686's Avatar
Default Re: EK fogs on a EG (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">lights are all wired up the same..
can't help you with that tho.</TD></TR></TABLE>
So i am able to use the EK harness, would it plug in the steering column; just like a 00'?
Old May 23, 2007 | 11:18 PM
bpr0422's Avatar
you said that the wiring is still intact right?
just wire the fogs to the wiring that is still at the bumper..
unless when u said that they were stolen.. that they ripped out the wiring and the fogs.
Old May 24, 2007 | 06:57 AM
Jdm_Eg686's Avatar
unless when u said that they were stolen.. that they ripped out the wiring and the fogs.</TD></TR></TABLE>
i no longer have the wiring they were ripped out.
Old May 24, 2007 | 02:10 PM
Jdm_Eg686's Avatar
bump...anyone?
Old May 24, 2007 | 02:21 PM
itzlance3's Avatar
i dont sorry
Old May 24, 2007 | 02:44 PM
iCONxEG21's Avatar
I DONT KNOW but it sounds really nice and i might plan to do it to mines too
Old May 24, 2007 | 03:09 PM
Egcoupe1995's Avatar
yeah u will have to cut into the bumper to make them fit my buddy did that with his eg coupe but be careful not to crack the bumper while doin it but the wiring u should be able to use the ek wiring harness to
Old May 24, 2007 | 06:37 PM
White95SiHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm_Eg686 &raquo;</TD></TR><TR><TD CLASS="quote">
i no longer have the wiring they were ripped out.</TD></TR></TABLE>
I installed some Raybrig EK fogs (from passwordjdm) in my cousin's 00 sedan, the harness is different from the genuine Honda EG fogs, the Depo fogs, and the Esuse fogs. There were 2 big male/female plugs by the steering column that's bridged together by the EK harness. I don't remember seeing that in the EG.
Another option is to get a EG fog harness. Or you can just use any universal fog/auxiliary light harness. Price ranges anywhere from $10-25, depending on where you buy it. You can either splice the universal harness into the the EK fog wiring (you'd have to cut off the plugs), or use female spade connectors to connect to the plugs on the EK fogs.
I mounted a rocker switch onto the block off plate by the defrost switch. Other places you can mount the switch are on the block off plates by the parking brake.
As far has cutting into the bumper, I can't help you there.
Old May 24, 2007 | 11:12 PM
Jdm_Eg686's Avatar
Default Re: EK fogs on a EG (White95SiHB)
awesome, thank you for all the replies, helps out a bunch
Old May 25, 2007 | 04:17 AM
jdm91CrxSi's Avatar
i have ek fogs on my eg looks oh so beautiful
Old May 25, 2007 | 05:21 AM
hondahannah's Avatar
PIX?? THNX
xmrxnguy3nx
Nov 6, 2009 02:47 AM
NathanAZ
26
Oct 10, 2008 07:46 PM
polyhonda
Jan 14, 2008 05:56 PM
VNTEC
Dec 9, 2005 06:40 AM
ralphie14
Dec 28, 2004 01:40 PM
