Rattling muffler
Old May 23, 2007 | 06:27 PM
Midori Green's Avatar
Default Rattling muffler
my muffler is rattling on my 96 hatch and i replaced the other one i had because it had a hole and the one i have know which is like 1 year old has been rattling since i put it on and i know this is the problem because while its running i push it up with my foot and the sound stops... what should i use to hold the muffler up and stop rattling... omg it wasnt this bad but now everytime im at a red light i hear it so loud... somebody give me some suggestions...thanx
Old May 23, 2007 | 06:28 PM
97Ej6mike's Avatar
Do you mean to say the actual muffler is rattling against something, like the bumper, or loose bolts on the flange? Or do you mean to say that it has things inside of it rattling?
Old May 23, 2007 | 06:32 PM
Default Re: (97Ej6mike)
no not inside of it just he muffler itself is rattling... like when i hit potholes it goes up and down a bit and makes that loud *** rattling sound at idle... but like i said the muffler is like a year old so it works and sounds fine when i hit the gas so the muffler itself and has nothing rattling inside
Old May 23, 2007 | 06:34 PM
97Ej6mike's Avatar
Well, it may be hanging wrong due to too short (or even too long) of hangers.
Could be a number of things
- Hangers are too short, the tip or even the muffler itself is touching the bumper or actual underside of the car.
-Hangers are too long, or theres not enough bend in the axle-back section, so its making contact with the Lower Control arm.
- Check to make sure all the bolts in the flange for your axle-back are tight.
Those are pretty much the 3 major things that it could be if the muffler itself is rattling. If anything, raise or lower your idle, that way it wont do that so bad at idle. Youd be surprised what a difference raising your idle a few hundred RPMs would do. If your Idle is too low, it will obviously rattle your entire system.
Old May 23, 2007 | 06:40 PM
you hit the nail on the head... when my car is at low rpms its horrible i have to literally hit the gas for the sound to stop and its embarrasing when i got chicks in the car u know? and by the way my car is automatic so its always at low rpms
Old May 23, 2007 | 06:41 PM
97Ej6mike's Avatar
Raise your idle then, any exhaust system with too low of an idle will rattle like that, has to do with natural harmonics and sound frequency. Phyics stuff, i wont get into it.
Old May 23, 2007 | 06:45 PM
ok... how do i raise my idle?... and i remeber i heard its not good to raise the idle but i cant remember why
Old May 23, 2007 | 06:50 PM
97Ej6mike's Avatar
Well, its simple, If you have the standard sidemounted Manifold ( not the D16y7's bastard child downdraft manifold, lol) then there is a screw on the very top of the Throttle Body, thats facing to the passenger side, its located in an circle-indentation, you cant miss it, its very visible. You turn it to one way to raise or lower, im not sure, you can figure it out on the spot, it raises\lowers it slowly so you'll have time to figure it out on the spot. Im failry sure its clockwise to raise the idle. Bring it to anywhere from 750 to 1000 RPMs, basically anywhere in that area that you find it doenst rattle.
Old May 23, 2007 | 06:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Well, its simple, If you have the standard sidemounted Manifold ( not the D16y7's bastard child downdraft manifold, lol) then there is a screw on the very top of the Throttle Body, thats facing to the passenger side, its located in an circle-indentation, you cant miss it, its very visible. You turn it to one way to raise or lower, im not sure, you can figure it out on the spot, it raises\lowers it slowly so you'll have time to figure it out on the spot. Im failry sure its clockwise to raise the idle. Bring it to anywhere from 750 to 1000 RPMs, basically anywhere in that area that you find it doenst rattle.</TD></TR></TABLE>
nice... good info... but yea i have the goofy y7 manifold... is it the same procedure?
Old May 23, 2007 | 06:59 PM
97Ej6mike's Avatar
hahaha nice, i had one once, their hard. Ok hmm, let me think, its the same thing, but in a diff position. Theres a screw on the Throttle body, if it hasnt been touched with before, there will be a rubber gasket\cover over it that prevents dust\dirt from getting on it. Remove that, and do as i had said before. Im going to searchup some more on where it is exactly, maybe a picture or two, but as i said, its on the actual TB, and in plain sight. From what i remember with mine, it was facing striaght up actually, and was easy.
Old May 23, 2007 | 07:01 PM
you the man... try to get a pic if u can... if not forget it i'll just look myself... thanks for all the help bro
Old May 23, 2007 | 07:10 PM
97Ej6mike's Avatar
Not much luck finding a picture or anything related to y7 manifold, just allota threads asking about swapping from y7 to 78 ( standard style) manifold. I had the Y7 awhile ago, and man oh man was it a bitch to work ok, lol everything is diff and weird, compared a normal one on most honda motors, lol.
If worse comes to worse, get a service manuel for your car, it will be worth it in the long run, how can you go wrong for like 15 $. It can be found at any local car store.
Old May 23, 2007 | 07:11 PM
97Ej6mike's Avatar
Actually, thsi site has downloadedable ZIP files, adobe's of the service manuels, find the one for your year on there.
http://spoonhonda.com/index_ie.htm
Old May 23, 2007 | 07:15 PM
actually my car has the original service manual lol i guess im a lucky one u dont see that much with these cars specially a 10 year old one
wodiej
Aug 20, 2017 04:07 AM
toshko321
18
Jun 9, 2011 01:05 PM
integra714
Feb 7, 2005 09:41 PM
mv10s
Mar 30, 2004 08:59 PM
jabroni95gsr
Feb 19, 2003 08:23 AM
