old gas.
Old May 23, 2007 | 05:09 PM
r1ch1e's Avatar
Default old gas.
i had my car sit for a year and a half. there was half a tank of gas in there. does gas go bad? i had a couple of mechanics tell me that gas does go bad. so just want to see if anyone ran in to bad gas.
Old May 23, 2007 | 05:26 PM
haroldthefly91crx's Avatar
Default Re: old gas. (r1ch1e)
there is bad gas. it turn yellow and you car will run like ****, could even mess up injectors or fuel pump, dump it out and fill with new gas, then replace the fuel filter just to be safe.
better safe than stuck on the side of the freeway
Old May 23, 2007 | 05:41 PM
Tippyman's Avatar
Default Re: old gas. (haroldthefly91crx)
There is a drain on the gas tank. Just undo it and let it drain.
I would do that, then pour about a gallon in the tank, swish it around, shake it up, and then drain it again.
Then change the fuel filter and when you fill up the car again, add some injector cleaner.
Old May 23, 2007 | 07:04 PM
r1ch1e's Avatar
Default Re: old gas. (Tippyman)
awesome!!!!!!!!!! i think i just figured out my problem i'm going to get some 93 octane with 4 bottle of injector cleaners and 2 bottle of octane booster. because it's in my yard and i don't think my parents will be too happy about me draining the gas.
Old May 23, 2007 | 07:07 PM
Tippyman's Avatar
The problem is when gas begins to break down, not when it loses octane values. It gets very gummy and nasty.
Old May 23, 2007 | 08:22 PM
there is such a thing as too many addatives
Old May 24, 2007 | 10:49 AM
r1ch1e's Avatar
dam it gets gummy? now that i have to drain but i have to ask my moms first. is that flamable? i'm guessing not because it's not starting. so i can dump it into the sewer
Old May 24, 2007 | 11:34 AM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1ch1e &raquo;</TD></TR><TR><TD CLASS="quote">dam it gets gummy? now that i have to drain but i have to ask my moms first. is that flamable? i'm guessing not because it's not starting. so i can dump it into the sewer</TD></TR></TABLE>
Into the sewer?
You can but it's not legal.
wolverinept
May 16, 2007 06:25 PM
HondaHemi
Dec 3, 2005 05:51 PM
ahhart
Jan 9, 2005 02:03 PM
96SR-V
Apr 19, 2004 09:18 AM
SjCiViCHB
Feb 14, 2003 06:35 AM
