B20 Vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikcivic95 »</TD></TR><TR><TD CLASS="quote">toda timing belt and any vtec water/oil pump. the non vtecs wont flow for jack. </TD></TR></TABLE> Why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmbeegee »</TD></TR><TR><TD CLASS="quote">i have a b20z2 block b16 head and need to know what timing belt and water pump is best for b20 vtec
gsr and any 22tooth water pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM »</TD></TR><TR><TD CLASS="quote">OEM ITR timing belt, water pump and oil pump
you do realize it's no different from a b18c1 set
</TD></TR></TABLE>you do realize it's no different from a b18c1 set
gsr timing belt and 22T water pump. ANd while your at it ditch that stock b20 oil pump and get a itr one or a gsr (if you can find it. number has been sustained with a PR4 number)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jkeno112 »</TD></TR><TR><TD CLASS="quote">gsr timing belt and 22T water pump. ANd while your at it ditch that stock b20 oil pump and get a itr one or a gsr (if you can find it. number has been sustained with a PR4 number)</TD></TR></TABLE>
all 96+ b series oil pumps are the same. so his b20z already has a "gsr" oil pump.
B20 OIL PUMPS ARE FINE FOR THE VTEC CONVERSION, AND THE LS B20 WATERPUMP IS ALSO OKAY TOO.....HAVE DONE IT WITH B20/LS WATER/OIL PUMP DOZENS OF TIME WITH EXCELLENT RESULTS....
Dr.Octagon
Jun 12, 2006 07:42 AM
