Vtec crack sith CEL?? WTF???
I just got a 95 DX with a B16. It came with the CEL on. I checked the code and it was a 1 for O2 sensor. For engine mangement it had an Shogan piggyback,(which is now for sale). It would crack Vtec but seemed like it had tuning issues, since it would pick up quick form 2000rpms to 4500rpm, then it would feel way slower form 4600rpms to 5500rpms. At 5500 is when vtec cracks, then the car comes back to life and huals ***.
So i decided to remove the Shogan and hooked up a STOCK P28. The O2 CEL code still pop on. I when to drive the car and it acted EXACTLY the same!! It picked up quick, got slower, then vtec cracked. All this with a CEL, on a stock ECU.
what the hell is going on???
Maybe its running to rich or lean cuz it needs an o2 sensor? Hence it is throwing a code for the o2 sensor. I could be wrong tho, but it is a good place to start.
i understand that but Vtec should NOT crack if the CEL is on. Right????
i'd like to know what would make the vtec still crack???
if your VTEC is "cracking" then you might want to get that fixed first. then fix your o2 sensor. then get your ecu tuned or chipped for a b16.
Modified by madpipr at 11:31 PM 5/23/2007
not trying to steal the thread but i kind of have a similar problem, in the sense that its the exact opposite.
im throwing a cel, but i really cant tell if its trying to be 25..26 or even 36?
i have a 94 del sol with a b16 swap and i did it myself and then took it to get the vtec wired by a creditable shop. I was told there to replace the knock sensor then the vtec would engage.
well the problem is im running a chipped p28 that doesnt read for a knock sensor, and my vtec still wont engage. What could my problem be?
xrsallday
Oct 23, 2010 05:48 AM
MysteryWagon
Mar 10, 2005 08:07 PM
