brake booster and mc problem need help asap!
ok i have a 94 hb vx i did a rear brake conversion,disk brake from gsr and i also have a 00 si brakes on front everything fits ok but my problem is that i was trying to get a brake pedal feel so i both a ls brake booster and put a a rs mc but after instalition my front brakes is dragging and it locks up i found out that the ls brake booster has a longer rod i try to adjust it but its just too long for the rs mc causing the brake drag cause the rod is already pushing the brake fluid by bolting on the mc,is there anything i could use aside from ls booster?or any mc that will work on my booster without modifiying my brake lines?
why didnt you just stick with your stock M/C and BB? or just upgrade the M/C alone?
i have all integra suspension from a GSR on all four corners of my hatch, and i'm running my stock M/C and BB without any trouble whatsoever...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchling »</TD></TR><TR><TD CLASS="quote">why didnt you just stick with your stock M/C and BB? or just upgrade the M/C alone?
i have all integra suspension from a GSR on all four corners of my hatch, and i'm running my stock M/C and BB without any trouble whatsoever...</TD></TR></TABLE>
Why have bigger front brakes when you're not using their full braking potential? Upgrading to a bigger MC/BB is a great upgrade.
I am not sure how (if any) different the LS and RS Brake Booster are, but if they are then switch to an RS brake booster and see if that solves your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
because my stock M/C and BB lock up the tires just fine on their own. didnt see a need to make them grab any harder.
</TD></TR></TABLE>because my stock M/C and BB lock up the tires just fine on their own. didnt see a need to make them grab any harder.
because my stock M/C and BB lock up the tires just fine on their own. didnt see a need to make them grab any harder.</TD></TR></TABLE>
Yes but when you have bigger discs and pads they are not being used to their full potential with a smaller MC/BB.
Yes but when you have bigger discs and pads they are not being used to their full potential with a smaller MC/BB. </TD></TR></TABLE>
yeah i know. but my stock M/C and BB lock up the tires enough on their own. i dont see a need to make that happen any easier...
its one of those many things on the list, but far from the top.....
