TYPE R & GSR
LOTS.....
But here is a quick few
Type R: GSR:
195 hp @8000 rpm 170 hp@7600 rpm
130 tq @7500 rpm 128 tq@6200rpm
2672 lbs 2529 lbs
No Sunroof option Sunroof option
10:6:1 compression ratio 10:1 compression ratio
This is just a very few I could think of. I am sure someone will chime in and give you more than that but at least that gives you an idea.
Type R: GSR:
2672 lbs 2529 lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy »</TD></TR><TR><TD CLASS="quote">GS-R's come with a DOHC VTEC badge on the back but the Type-R comes with not 1 not 2 but THREE!!! Integra Type R decals!!!</TD></TR></TABLE>
Shibby! Def worth $17,000!!! Oh, and don't forget teh H-I-Dizzles!
gsr
sunroof, 170hp, optional leather seats, 8.2k redline, 17mm swaybar, 4 lugger.
itr
no sunroof, nice black with red stiched interior, 8.6 redline, 22mm swaybar, 198hp, 5 lugger, wing, itr lip, comes in great colors (champ white, nhbp, sy)
in motors
gsr comes with 170hp, smaller cams, lower compression pistons
ITR comes with a light P&P head, higher compression, 4-1 header.
JDM ITR comes with a bump in compression resulting in a little bit more hp.
itr
in motors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4 jdm lude »</TD></TR><TR><TD CLASS="quote">what is the differences in the GSR and the Type R</TD></TR></TABLE>
You sir/mam are is too teh funnies!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABCVTEC »</TD></TR><TR><TD CLASS="quote">
Shibby! Def worth $17,000!!! Oh, and don't forget teh H-I-Dizzles!</TD></TR></TABLE>
USDM Integras have never had HID headlights available.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Championship »</TD></TR><TR><TD CLASS="quote">gsr
itr
in motors
JDM ITR comes with a bump in compression resulting in a little bit more hp.</TD></TR></TABLE>
What?
GSR redline is 8, ITR is 8.4
itr
in motors
What?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdgcgpgsr »</TD></TR><TR><TD CLASS="quote">What?
GSR redline is 8, ITR is 8.4</TD></TR></TABLE>
Talking about fuel cut-off, and not where the little redline starts.
Download this pdf. It is Acura's take.
http://www.hondahookup.com/manuals/?file=type r_technical_guide.pdf
You may need to join the site. Acura makes some of the things on the ITR seem unique that are also on the GSR (i.e. the oil cooler, though Acura removed that from the GSR in 1997).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Download this pdf. It is Acura's take.
You may need to join the site. Acura makes some of the things on the ITR seem unique that are also on the GSR (i.e. the oil cooler, though Acura removed that from the GSR in 1997).</TD></TR></TABLE>
Im telling you guys its the shell and chassis that makes it unique (and motor of course)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B92P_DC2 »</TD></TR><TR><TD CLASS="quote">
Talking about fuel cut-off, and not where the little redline starts.</TD></TR></TABLE>
Helps to be correct then, because the P72 ECU cuts fuel at 8100 rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">
Im telling you guys its the shell and chassis that makes it unique (and motor of course)</TD></TR></TABLE>
We know that. The Helm supplement that I linked covers it all, but with a slight advestising twist (the manual suggests that an ITR crankshaft has additional counterweights to the GSR, when in reality the counterweights as just heavier on the ITR).
