96 CIVIC EX Brake ABS question
Old May 23, 2007 | 08:37 AM
theeogflip's Avatar
Default 96 CIVIC EX Brake ABS question
I have 96 CIVIC EX. Does my car have brake ABS or without ABS?
B/c I need to get new axles for my car. Do I need to get the one w/ ABS or w/o ABS?
Modified by theeogflip at 9:48 AM 5/23/2007
Old May 23, 2007 | 09:37 AM
theeogflip's Avatar
Default Re: 96 CIVIC EX Brake ABS question (theeogflip)
bump.
Old May 23, 2007 | 12:58 PM
theeogflip's Avatar
bump
Old May 23, 2007 | 01:24 PM
EL Vap133's Avatar
Some did and some don't. Just look for the ABS lines/pump under the hood.
Old May 23, 2007 | 01:47 PM
JasonGhostz's Avatar
Default Re: 96 CIVIC EX Brake ABS question (EL Vap133)
Check your gauge cluster when you start your car. The ABS indicator will light up for 6 seconds before turning off by itself. If you don't have it, then you don't have ABS...
JasonGhostz
EDIT:... DUH... I confused the ABS indicator with the SRS indicator...
The ABS indicator will be part of your gauge cluster if you have ABS. Unless you swapped your cluster, this will be the easiest, simplest, and safest way to check (you can always just slam on your brakes on the road ). If you have it, it will be to the left of your Fuel Gauge, just to the right of the Mileage Reset Button. It comes on/off for different reasons, and not just when there's a problem.
Sorry about the confusion.
JasonGhostz
Modified by JasonGhostz at 3:16 PM 5/23/2007
Old May 23, 2007 | 01:58 PM
EL Vap133's Avatar
Get the one with ABS, I have "ABS" axles on my DX and it runs fine.
Old May 23, 2007 | 03:52 PM
theeogflip's Avatar
thank you so much for all your help. All advices were appreciated.
Old May 23, 2007 | 04:25 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theeogflip &raquo;</TD></TR><TR><TD CLASS="quote">thank you so much for all your help. All advices were appreciated. </TD></TR></TABLE>
No problem, all that is different is that the ABS axles have an "ABS" ring on them.
mitch2you80
Oct 21, 2004 04:36 PM
silentblackhat
Sep 16, 2004 03:47 PM
scoobyghost
Aug 30, 2004 06:15 PM
Hatchtrap
10
Feb 10, 2003 08:00 PM
