HELP > HELP > am I getting ripped off ? > HELP > HELP
Old May 23, 2007 | 07:18 AM
b18c1del's Avatar
Default HELP > HELP > am I getting ripped off ? > HELP > HELP
after spending over $2.5k for engine rebuild > drove the car only 2X then
sputtered & died in the fwy > discovered TWO unplugged plug wires off
the distributor > concord, ca import shop says they may have came loose
> they also said that dizzy is BAD & needs replacing & bad dizzy lead to
bad CAT which I also had to buy > I am asking all H-T TECHS for opinions
Old May 24, 2007 | 07:41 AM
Crispy's Avatar
Default Re: HELP > HELP > am I getting ripped off ? > HELP > HELP (b18c1del)
For 2.5k I'd expect them to attach the plug wires properly. Honest mistake though I guess, no biggie.
As for the Dizzy, whats bad? Cap and Rotor, or the whole unit? a cap and rotor can be replaced for like $15 and you can do it in under 10 minutes.
What I dont get is if these were bad wouldnt they have noticed that when they built the engine? and why on earth do you need a cat because your dizzy took a **** all of a sudden?
my 2 cents thinks theres either more to this than posted or you're getting taken for a ride with no lube.
Old May 24, 2007 | 08:21 AM
EE_Chris's Avatar
Default Re: HELP > HELP > am I getting ripped off ? > HELP > HELP (Crispy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crispy &raquo;</TD></TR><TR><TD CLASS="quote">my 2 cents thinks theres either more to this than posted or you're getting taken for a ride with no lube.</TD></TR></TABLE>
x2
lilmex
Aug 24, 2007 11:26 AM
prelude_93vtec
Jul 17, 2007 01:48 PM
b18c1del
May 23, 2007 07:57 AM
dogboy945
Apr 21, 2007 11:52 PM
Jameson
Mar 29, 2006 07:57 AM
