Air Conditioning Pulley Belt?
Old May 22, 2007 | 08:34 PM
agiorlando's Avatar
Default Air Conditioning Pulley Belt?
Hey everyone, the A/C on my car doesn't have a pulley belt on it, I just bought the belt for it, and I'm unsure how to put it on.
Does anyone have instructions or a diagram?
Car Information
Chassis: 1992 Honda Civic VX (hatchback)
Engine: B16A2 (JDM)
ECU: P30-000 (Canadian?)
Old May 22, 2007 | 09:38 PM
Xscort's Avatar
i have a b18b in my ej1 now. i think u have to remove the power steering belt before u get a/c. on the b18b, for the a/c there's a 12mm?? adjusting screw, i think thats all u need to use to swing the pulley up or down, then once u get the belt on tighten the adjusting screw. its real easy, u can look at it and see what all u need to do.
Old May 22, 2007 | 10:30 PM
agiorlando's Avatar
Default Re: (Xscort)
Sounds good about right.
I don't have power steering on my car, or do I?
There is no where to put any power steering fluid, but there seems to be an extra pulley.
Do some cars not use fluid and are just powered by the pulley and belt?
Old May 22, 2007 | 10:54 PM
crashzerothree's Avatar
Default Re: (agiorlando)
i pretty sure VX's dont have power steering, but there is a little pulley, i believe above your A/C compressor on the motor itself, loosen that put the belt over the A/C conpressor, over that tensioner pulley, and over the crank shaft pulley. then get something like a pry bar to put pressure onto the pulley. Make sure the belt is fairly tight, then tighten the pulley down.
MatthewMenze
Mar 7, 2013 03:42 PM
tl44
Jan 31, 2011 05:05 PM
porter
29
Jan 31, 2007 09:31 AM
luderollin
Feb 25, 2005 12:07 PM
Scharged00GsR
Jul 12, 2004 05:58 AM
