i need new spindle
Old May 22, 2007 | 08:05 PM
(760)doogie's Avatar
Default i need new spindle
hey so i was driving and pulled a u turn, the bolt thats screwed into the ball joint came off and the spindle dropped and everything. im going to the junk yark tomorow so do you think i should find a ball joint or a spindle and im thinking about getting the full on spindle so what cars can i take the spindle from. my car's a 91 hatchback si.
Old May 22, 2007 | 08:24 PM
Tippyman's Avatar
Default Re: i need new spindle ((760)doogie)
So the castle nut came off and the whole assembly scraped on the ground while you were driving?
Old May 22, 2007 | 08:30 PM
Default Re: i need new spindle (Tippyman)
this is gunna sound dumb but i didn't put the castle nut on, i put a different bolt on but ya that's what happened. and the part that the castle nut screw onto is trashed and it wont work anymore
Old May 22, 2007 | 08:46 PM
Tippyman's Avatar
Doesn't the castle nut just screw onto the ball joint? If so, couldn't you just get a new ball joint?
Old May 22, 2007 | 08:58 PM
that's wut im hoping for but i gotta check out the whole thing tomorow cuz it got too dark. but if the spindle is messed up, what cars can i use it from.
Old May 22, 2007 | 09:02 PM
Tippyman's Avatar
I would assume all EF's, since you can use mostly the same suspension components. If possible, stick to 90-91 hatches just to be sure until you can find out for sure.
Old May 23, 2007 | 12:56 AM
gRim06's Avatar
you can probably use parts from a 2nd gen crx as well, i had the same thing happen to me except the people i got the car from used a diff. nut and didnt bother with the cotter pin. i got around for a while like that. depending on how fast you were going would mostly determine whether there was any damage to your spindle. was just turning in a parking lot slowly(i previously lost traction in a stretch of the parking lot before the incident) if you weren't going very fast you shouldnt have to worry about anything but the ball joint.
Old May 23, 2007 | 07:18 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: i need new spindle (gRim06)
any 88-91 spindle will work, with the single exception being the 88-91 crx hf spindles, which use different axles.
Old May 23, 2007 | 08:17 AM
Default Re: i need new spindle (sanimalp)
alright so i forgot to say i have a b16 swap so i have 91 integra axles, does that effect what spindle i use
Old May 23, 2007 | 09:05 AM
mahatma's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by (760)doogie &raquo;</TD></TR><TR><TD CLASS="quote">alright so i forgot to say i have a b16 swap so i have 91 integra axles, does that effect what spindle i use</TD></TR></TABLE>
no but if you replace them remember to take out those dust rings from inside
Juans_MX3
42
Jul 10, 2021 04:38 PM
neopheus
Mar 18, 2005 10:53 PM
LX4CYL
16
Feb 13, 2005 03:12 PM
B18C_EJ8
Sep 14, 2004 09:32 PM
wildstallion
Jul 23, 2002 02:09 AM
