ARP head studs
Old May 22, 2007 | 07:21 PM
freddysEF's Avatar
Default ARP head studs
hey guys im starting to do my mini swap but i have a question about the head studs.
how should i installed the studs??? should i torqued the studs to the block?? i need help
i have studs, washers, bolts.
thanks
Old May 22, 2007 | 07:53 PM
Tippyman's Avatar
Default Re: ARP head studs (freddysEF)
Ummm... read the directions that came with the studs.
Old May 23, 2007 | 06:15 AM
mahatma's Avatar
i snugged them in hand tight with the allen key, before i put the head on. make sure it's nice & clean inside there....
Old May 23, 2007 | 08:42 AM
HBK's Avatar
HBK
Default Re: ARP head studs (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">i snugged them in hand tight with the allen key, before i put the head on. make sure it's nice & clean inside there....</TD></TR></TABLE>
If theres some **** in the holes, the studs might get tight sooner then supposed to. Make sure to follow the directions, use some lube and torque'em down
Old May 23, 2007 | 09:20 AM
freddysEF's Avatar
Default Re: ARP head studs (HBK)
how much should i torque them down to?
Old May 23, 2007 | 01:26 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBK &raquo;</TD></TR><TR><TD CLASS="quote">
If theres some **** in the holes, the studs might get tight sooner then supposed to. Make sure to follow the directions, use some lube and torque'em down</TD></TR></TABLE>
projectef
Nov 7, 2008 12:15 PM
Antilag
Oct 28, 2007 12:33 AM
skiracer8148
11
Aug 14, 2007 07:59 PM
civicb18Tkid
May 3, 2007 07:30 AM
Fatty_1775
Feb 9, 2006 11:02 AM
