92 prelude havin motor problems!!
Old May 22, 2007 | 06:53 PM
baggedlude's Avatar
Default 92 prelude havin motor problems!!
my 2.2s wont start have no fuel and no spark anyone know wut would cause this??
Old May 22, 2007 | 07:00 PM
AndyD's Avatar
Default Re: 92 prelude havin motor problems!! (baggedlude)
yO eye no wut da shyt b wrong chek da polch. Dat shyt wen bad on mah whip.
peace
Old May 22, 2007 | 10:16 PM
LudePR93's Avatar
If your not getting any fuel I believe it could be your fuel pump relay which is underneath your dash. Get a volt meter and check for current. As for your spark you might want to check your coil first then go down the line from there. Its not that hard believe me. There isn't much to an ignition system. Hope this helps.
By the way there is literature you can buy at your local auto parts store that has the factory specs on what the proper voltage should be for your ignition coils and other parts as well.
GRSears
Apr 15, 2016 04:22 PM
chase.vanatta
Jun 15, 2009 05:12 PM
k_d_2001
Nov 5, 2008 02:15 PM
bogey883
Sep 6, 2007 02:16 AM
whtwuzthat
Sep 3, 2004 05:09 PM
